Is there a way to adjust the idle jet screw without using a lifting pin or lifting the dashpot because the filter is on. looking for a procedure to adjust idle richness without taking off the air filter and my carb doesnt have a lifting pin for the dashpot like my hs4 did thanks
Any non-standard parts that might be involved with the problem?
Hif44 Adjusting Idle Richness With Out A Lifing Pin And Filter On
bantamben
, Feb 07 2009 03:52 AM
2 replies to this topic
Posted 07 February 2009 - 03:52 AM
Posted 07 February 2009 - 08:37 PM
there is an idle mixture screw under the fuel pipes, it counter bored and a bit hidden, is that the one you mean.
Posted 07 February 2009 - 08:56 PM
You can use something like a small screw driver in the carb throat to lift the piston directly - wire coat hanger?
