Fitting Sports Pack Arches
5 replies to this topic
#1 james_redfern
james_redfern
    Starting My Mini Up
  • 1 posts
Posted 13 August 2005 - 08:58 PM
Hi,
I am about to fit sports pack arches, but am not sure how they attach to the car. Bolts are already fixed to the arches. For the front, after drilling some holes, it looks easy enough to put nuts on the end and tighten. But the holes for rear arches seem to need drilling where the body is double skinned and the bolts don't look as though they're long enough to pass through both skins?
Any help appreciated.
#2 TVR TASMIN
TVR TASMIN
  • 26 posts
Posted 13 August 2005 - 09:47 PM
You will need to cut away a section of the front wings to fit the sportspack arches.
The rears i understand fit without too much prior modification. I don't think there is a double skin. You have probably drilled into the car interior behind the panels.
I have been told a template is available to fit these but don't know where it can be found.
I am about to fit a set and have similar concerns as yourself.
#3 Pooky
Pooky
  • 5,691 posts
Posted 13 August 2005 - 10:25 PM
You can fix the panels pretty much however you want. Rivets, screws, nut 'n' bolt!
The rear arches will need to be riveted/screwed tho because you can't get at the other side of the skin!
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 14 August 2005 - 12:25 AM
I don't know how the non genuine arches are fixed, but the rover ones have captive bolts moulded into them. It is then a matter of cutting away the front arch, drilling wholes in the wings in the right place and ataching with nuts from the inside of the wing/ boot/ car. The templates can be found on the Minispares website for free, only if you are registered with them. Its adviseble to drill all mounting holes about 8mm to ease alignment of the fixing bolts. I learned after fitting the first set.
james_redfern I have the template PDF files, if you PM me with your email address I'll zip them up and send it to you for you to print out.
#5 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 14 August 2005 - 08:16 AM
The templates are also on the TMF CD!! along with laods of other stuff!
only £5
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 August 2005 - 01:19 PM
Yeh... I didn't have to plug it this time....
PS... if you do use the templates, can you have a digi camera, how about writing a "How to Guide" to complement the arch templates on the CD ?
