What Is The Thickness Of Mini Body Panels?
18 replies to this topic
#1 robtheplod
robtheplod
  • 960 posts
Posted 08 February 2009 - 05:35 PM
.... is it 1mm, 1.2mm etc?? keen to practice on metal of similar thickness so i don't destroy the car once i turn my attentions to it >_<
Also, is the metal a different thickness in say the boot floor etc??
Edited by robtheplod, 08 February 2009 - 05:36 PM.
#2 Ethel
  • 25,928 posts
Posted 08 February 2009 - 05:42 PM
I'll guess it's mostly 22swg ('bout 3/4mm) but will obviously vary where it's been stretched in the press.
#3 robtheplod
robtheplod
  • 960 posts
Posted 08 February 2009 - 05:51 PM
what would that be in mm ??
#4 robtheplod
robtheplod
  • 960 posts
Posted 08 February 2009 - 05:56 PM
sorry read that again - 3/4 mm !!!! (dough!)
#5 james105
james105
  • 466 posts
Posted 08 February 2009 - 06:04 PM
I wouldn't say the body panels were anywhere near 3/4mm, 1.2-1.5mm at a guess.
#6 Burnard
Burnard
  • 3,350 posts
Posted 08 February 2009 - 06:17 PM
less than 1mm. ive been practiceing on 1mm, and its definatly thicker than the cars metal.
0.75mm soungs about right to me, could be 0.8mm, ill mesure it now...
*runs to garrage*
0.79mm exactly probably ment to be 0.8mm
Chris
#7 RacingGreen
RacingGreen
  • 2,111 posts
Posted 08 February 2009 - 06:23 PM
He didnt say 3-4mm, he said 3 quarters of 1mm. if the whole car was made out of 3mm steel then it wouldnt move >_<
#8 tommy13
tommy13
  • 878 posts
Posted 08 February 2009 - 06:28 PM
Always used 20swg (.914 mm) it's a thickness commonly held by factors, is roughly same thickness as many of the panels on the mini, although they do vary a lot. It is not too thick to bend and shape easily and isn't so thin the mig blows holes in it easily.
#9 midridge2
midridge2
  • 1,794 posts
Posted 08 February 2009 - 06:40 PM
as said by ethel, the average factory panel is 20-22 swg.
#10 james105
james105
  • 466 posts
Posted 08 February 2009 - 08:03 PM
He didnt say 3-4mm, he said 3 quarters of 1mm. if the whole car was made out of 3mm steel then it wouldnt move :lol:
That would make more sense! My bad! Read it wrong!haha! FAIL!lol
#11 robtheplod
robtheplod
  • 960 posts
Posted 09 February 2009 - 09:04 AM
so if I go for 0.8mm I should be fairly close to a typical panel thickness?
keen to practice welding on metal that is close to the original so I don't blow holes everywhere!!
thanks for all your replies!
rob
#12 robtheplod
robtheplod
  • 960 posts
Posted 10 February 2009 - 08:55 AM
Assuming this steel plate is solid (picture not clear!), would this suffice to use for plating??
http://www.diy.com/d...?...mp;x=24&y=6
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 February 2009 - 09:14 AM
You'd be better going down the local dump and ripping the side of a fridge...
to be honest, if you're patching something, generally the most economical way to do it is to buy a repair panel... the majority of the panel will then be already shaped to your need, and if there's any you don't need then you have some spare metal for other bits...
#14 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 10 February 2009 - 10:13 AM
He didnt say 3-4mm, he said 3 quarters of 1mm. if the whole car was made out of 3mm steel then it wouldnt move :shifty:
Bullet proof!
#15 daemonchild
daemonchild
  • 2,341 posts
Posted 10 February 2009 - 10:21 AM
That's pretty much what I'm planning to do.
Going to go to scrappy and pick up a few crappy panels for next to nothing.
But, then when I have a good weld going, I'm going to do the rear valance and then an a-panel. (10 and 5 each!)
