Which Dzus Fasteners Do I Go For?!?!
9 replies to this topic
#1 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 09 February 2009 - 09:32 PM
hiya peeps
ive got to order some Dzus fasteners for my new front end, and im stuck between two types.
what do you guys and gals think i should go for? any reasons?
Number 1:
Linky 1
Number 2:
Linky 2
cheers
adam :P
oops spelling mistake in title :P
Edited by stardude, 10 February 2009 - 01:17 AM.
#2 stardude
stardude
  • 2,457 posts
Posted 10 February 2009 - 11:01 AM
bump
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 February 2009 - 01:02 PM
I have seen both types used on fiberglass body panels (non-Mini). My personal preference for composite panels is the second type because the part you rivet in place behind the bottom panel attaches better/firmer. The spring wire clip shown in the first link is fine for sheet metal but over time I've seen them work loose on fiberglass panels.
#4 GraemeC
GraemeC
  • 7,453 posts
Posted 10 February 2009 - 01:11 PM
But generally would the spring wire clip would be affixed to whatever the f/glass front was being locked onto - usually a steel or alloy bracket rather than another f/glass piece?
With the second type - what holds the quarter turn fastener to the outer panel? Or is it free to get lost? With no metal flange as per the first example I would expect it to damage, if not pull through, the f/glass panel.
#5 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 10 February 2009 - 04:03 PM
I agree GreameC type one, fit spring to metal bracket, I do not know about the others looks like the head has not got a plate to spread the load.
some duzs fasteners on ebay are copies which are ok but some are not cut deap enough in the slot and are a pain to undo.
#6 Pooky
Pooky
  • 5,691 posts
Posted 10 February 2009 - 04:06 PM
I didn't want anything showing on the outside of my flip front so used latches such as these suitcase type latches.
Fix one half to the front, one too the A-panel, have some sort of seal in-between that the front can squeeze onto.
Mine work really well :shifty:
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 February 2009 - 04:44 PM
I see GraemeC's point. I had not considered that on the flip-front Mini the spring would be riveted to metal. Again, my experience has been with two fiberglass panels held together.
You are also correct that the second type of Dzus has a completely removable fastener. You do have to be careful not to lose them... or carry spares with you. They don't damage the panel particularly but you have to locate the through-hole for them accurately during initial installation.
#8 stardude
stardude
  • 2,457 posts
Posted 10 February 2009 - 05:36 PM
i think i will be going for the first type.
does anyone know what depth clips i will need?
cheers
adam
#9 2lrminivan
2lrminivan
  • 276 posts
Posted 10 February 2009 - 05:42 PM
im using the first type on my steel removable front and hate them have to line it up spot on and if u slip with the coin u use to lock it it will scratch the paint.im looking for a different system to use
#10 barrythebodger
barrythebodger
  • 77 posts
Posted 11 February 2009 - 05:01 PM
#hijack#
I'd also like to know what size dzus fasteners to use? I dont fancy forking out £20 + postage for the ones on ABS
thanks
Edited by barrythebodger, 11 February 2009 - 05:02 PM.
