[b]Year:1991
[b]Description of problem engine turns when ignition lights on
[b]Any non-standard parts that might be involved with the problem? using remote type solenoid as older engine than original and can't use piggy back owing to ring gear being different on A series
Connected up, expecting it to all go great, and as soon as i put key on 'ign light' on then the solenoid kicks in and turns engine. If i take off the small white/yellow, then it acts as it should. I have poured over the diagrams, and it appears I have a starter relay, which the older engine wouldn't have had. Has anyone had a similar issue???
This is after i got all the other GREMLINS out of the wiring, getting all lights etc working AAAAHHHHHHHHHHHHHH!!!!
Right going for a couple of beers to get the thinking cogs going
Any help appreciated PLEASE
Edited by markospondon, 10 February 2009 - 08:33 PM.
