Weber 40 Fuel Pressure
3 replies to this topic
#1 scotchmist
scotchmist
  • 92 posts
  • Local Club: Minisunlimited
Posted 11 February 2009 - 05:59 PM
What fuel pressure is required for a weber 40DCOE? Is the standard mechanical fuel pump without pressure regulator sufficient?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 February 2009 - 06:05 PM
4-5psi i believe. For a good spec engine, it would need to be regulatored to provide constant pressure and most likely a elec fuel pump.
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 11 February 2009 - 09:24 PM
Im running a std pump on mine atm with a std 1275 and is fine even when giving it serious abuse!, not sure what im going to do when the 1330 goes in though........ :dontgetit:
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 11 February 2009 - 09:35 PM
You should ideally run a solid state Facet electric pump as close to the tank as poss. Use a regulator (Filter King is about the best) to regulate the pressure to 4 psi as said above.
Paul
