Brake Fluid Warning Light Is On Despite Adequate Fluid Levels
2 replies to this topic
#1 mcaville
mcaville
  • 144 posts
Posted 11 February 2009 - 07:16 PM
The brake fluid warning light has come on despite there being adequate fluid levels. Why?
Sprite Auto:
1994:
The red brake warning light on the dash console has started coming on. I immediately consulted the manual and discovered that this is an indicator that the brake fluid levels had dropped too low. I purchased some DOT 4 fluid before checking the level, but on inspection it seems that the levels are absolutely fine - way above minimum. As i had just bought the fluid i topped it up to max anyway. The problem is that the light still comes on. It is always on when i get in the car but sometimes goes off once i have been driving for 10 minutes or so.
Can anyone tell me what might be wrong? The car doesn't seem to have a problem with stopping, but if there is a potential problem i like to get on it as quickly as possible.
Martin:
#2 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 11 February 2009 - 07:24 PM
check the brake filler cap for any defects as these cause issues with the warning light if stuck or the contacts corroded
#3 Disco Dan
Disco Dan
  • 332 posts
  • Local Club: MCCoA
Posted 12 February 2009 - 07:53 AM
Remove the cap and clean it with brake fluid. You can see the switch in the lid to inspect, also check contacts.
Also check the wires going into the switch - they are 4 wires going to the switch, two for the bulb in the switch the other two for the 'test'. You may have a loose wire or false ground?
