Runing With Choke
7 replies to this topic
#1 finch661
finch661
  • 2,339 posts
Posted 12 February 2009 - 10:50 AM
hi, i just want to double check something, regarding my choke/carb set up. i have found that even with full choke, i only get a rev increase to around 1800-2000rpm, which it used to sit at about 3000rpm. and if put the choke in all the way, even though the engine is warm, it stalls. am i right in thinking that the mixture is a wee bit lean?
thanks
oh ive got a standard 85 mayfare with 998 engine
:wub:
#2 mini mark
mini mark
  • 876 posts
Posted 12 February 2009 - 11:01 AM
most probably a bit lean, make the mixture a little bit higher and see if its ok if not try a little bit more but not loads, its not recovering itself with enough fuel to keep it running thants what i think
#3 lrostoke
lrostoke
  • 6,923 posts
Lots of things could be really
carb mixture
timing
tickover adjustment on choke setting and normal setting.
minor air leak.
#4 finch661
finch661
  • 2,339 posts
Posted 12 February 2009 - 11:13 AM
carb mixture
timing
minor air leak.
when you say tickover adjustment on choke setting, what/how?
thanks
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 12 February 2009 - 11:24 AM
Attached File  carb.JPG   46.9K   9 downloads
Screw No 1 is the fast tickover adjustment. (choke on)
No 4 is normal tickover (no choke)
#6 finch661
finch661
  • 2,339 posts
Posted 12 February 2009 - 11:28 AM
ah, right, so when you have the choke on full, you can adjust the "choke idle" speed. so i will need to crack out the stubby screwdriver
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 12 February 2009 - 11:36 AM
Best adjust it with the choke off, just adjust that screw so it isn't quite touching the choke cam.
#8 finch661
finch661
  • 2,339 posts
Posted 12 February 2009 - 11:37 AM
coolio, i will take a look tomorrow, thanks for all your help (everyone)
:wub:
Edited by finch661, 12 February 2009 - 11:39 AM.
