Brake Judder
10 replies to this topic
#1 minitalia1275
minitalia1275
  • 98 posts
  • Local Club: MiniFriendsTorino
Posted 12 February 2009 - 09:09 PM
Mini Cooper (carb)
1991
I have a 1991 Mini Cooper (carb model). The problem is that there is lots of judder and vibration from the front wheels when braking at high speed. I'm not sure if the vibration is at only one wheel or both. I have checked the suspension and all is ok. I changed the pads and the judder went away but returned after a 1000 miles. I changed the discs and pads again but the problem is still there. I tried normal mintex pads which were much better than the green stuff pads.
I am very grateful for any help and tips.
Thanks to all in advance.
Rob
#2 BenLAST
BenLAST
  • 323 posts
Posted 12 February 2009 - 09:15 PM
check that the hub bolt is tightened up to about 120nm. your tracking could be out or the wheels are out of balance.
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 February 2009 - 09:32 PM
things to check
1) discs are tight on the drive flanges
2) the drive flanges are clean and square on the mounting face to wheel bearings, and disc face
3) the brake calipers where pads fit is corroded or worn
dave
#4 smorg
smorg
  • 137 posts
  • Local Club: brightonminiclub.co.uk
Posted 13 February 2009 - 11:41 AM
i doubt it but you could have warped disks which could be causing it
#5 carthy79
carthy79
  • 45 posts
Posted 13 February 2009 - 11:45 AM
I had this same problem in a clio when I changed the discs and pads a couple of times but still came back. It's going to have to be a process of elimination and start by getting the wheel alignment sorted and front wheeels balanced - sounds like it could be this has you only have the judder at high speed.
#6 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 13 February 2009 - 09:45 PM
my car was juddering, turned out to be warped discs... fitted new discs, twice (!), but they just keep warping.... any ideas? Think it could be something in the caliper(s).
#7 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 13 February 2009 - 09:55 PM
could be wheel bearing or the wheel balancing both cause warping and judder
#8 john1.2pearl
john1.2pearl
  • 341 posts
Posted 13 February 2009 - 11:11 PM
if new discs and pads were fitted then the juddering came back after a while to me it points to a binding brake caliper causing the pads not being able to return and keeping pressure on the friction face of the disc and pad causing the disc to heat up thus causing another warped disc
#9 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 13 February 2009 - 11:29 PM
Sounds like warped discs to me.
#10 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 14 February 2009 - 01:25 AM
thanks very much, that sound about right. what can I do to fix it? do I need a whole new caliper(s)? Or are they refurb-able etc?
Mark
#11 mozzo1
mozzo1
  • 287 posts
Posted 14 February 2009 - 11:39 AM
=] this is so true because where alot of people go wrong fitting new pads is that they dont clean the pistons first before pushing all the rust and grime into the seal coarsing the caliper the stick, so i would defo start by checking your calipers
