I've got a cylinder head stitting in my garage that I was told had been modified.
From inspection the ports have been smoothed and tidied up.
I've pulled a couple of valves out and measured them
The inlet valves are 29.9mm (cam 6502)
The exhaust valves are 24.5 (cam 6505)
I'm pretty sure these are standard valves?
It a leadfree head as well
What spec would you say this head was?
Shifty
Standard Valve Sizes 998a+
Shifty
, Feb 13 2009 05:22 PM
3 replies to this topic
Posted 13 February 2009 - 05:22 PM
Posted 13 February 2009 - 05:40 PM
1" exhaust
1 & 3/32" Inlet
1 & 3/32" Inlet
Posted 13 February 2009 - 05:48 PM
Thank Ethel, by my calculations that make the standard inlet valve about 27.6mm
So it has been played with then.
Woo Hoo, for sale section here we come!!
Posted 13 February 2009 - 06:38 PM
http://www.minimania...26/ArticleV.cfm
Any casting numbers, because those sizes are pretty much Cooper head sizes
Also are you sure on the sizes, those part numbers you give according to somerfords site
6502 = 27mm
6505 = 25.4
http://somerford-min.....nd 1098cc.pdf
6502 = 27mm
6505 = 25.4
Edited by lrostoke, 13 February 2009 - 06:43 PM.
