Removing Primary Gear Seal With Engine In Car
12 replies to this topic
#1 bantamben
bantamben
  • 64 posts
  • Local Club: no
Posted 15 February 2009 - 10:23 PM
I about to try to replace my primary gear seal today. I purchased the installation tool and sleeve so i can do it right. My question is what is the best way to remove the old seal. thanks
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 16 February 2009 - 12:31 AM
hook it out, or pull the primary gear
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 16 February 2009 - 06:18 AM
Ive got a tool to remove and install the primary gear and seal. But pulling the gear usually works and will fetch the seal out with it.
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 February 2009 - 07:42 AM
As above really, I've usually got away with just pulling the primary gear and bringing the seal with it.
To replace it, I usually fit the seal onto the primary gear and then put the whole lot back in together, rather than putting the gear in and then trying to slide the seal onto it. Just be gentle with the new seal and make sure it's seated and aligned correctly.
#5 GraemeC
GraemeC
  • 7,438 posts
Posted 16 February 2009 - 11:26 AM
Hardest part of the whole operation will be removing the flywheel with the engine in situ. Not impossible by any means but if the flywheel has a good hold then its not a fun task!
#6 bantamben
bantamben
  • 64 posts
  • Local Club: no
Posted 16 February 2009 - 06:08 PM
yeah actualy i have he cutch removal tool and a really big ratchet to get it off. wasnt a problem the first time. Im just wondering a few of you mentioned pulling the pprimary gear do you just pull the c washer clip and just pull the gear off by hand to get the seal out or do you use some sort of puller. thanks
#7 bantamben
bantamben
  • 64 posts
  • Local Club: no
Posted 17 February 2009 - 01:03 AM
bump bump please help im stuck if anyone knows the best way to get off the seal im at that point some have suggested letting the primary gear pull it off but what do you use to pull of the gear and seal as the seal is in there pretty good
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 February 2009 - 08:42 AM
Unfortunately it's another special tool which removes the primary seal. It's grips the primary gear in the grove between then clutch splines and the seal face on the primary gear and then pulled using a similar method to a flywheel puller, but thinking about it, you could manufacture something out of something like an 1/8" thick metal plate (like a big C washer) which could fit into this grove, and then 3 holes for the flywheel puller to attach to. It does not take a lot of pressure to pull the primary gear (with the seal).
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 18 February 2009 - 12:06 PM
Ive got the tool that guessworks describes
And the re-fitting tool.
Comes in handy if your doing this often
Jordie
#10 bantamben
bantamben
  • 64 posts
  • Local Club: no
Posted 18 February 2009 - 01:14 PM
thanks i ended upp using a big ppry bar on the edge of gear and the edge of the case after a little persuasion it popppped out. then with the tool it went in smooth and no leaks thanks
#11 Dusky
Dusky
  • 5,322 posts
Posted 14 November 2014 - 09:20 AM
Any pictures of this tool. I'll have to make one myself I guess.. :P
#12 GraemeC
GraemeC
  • 7,438 posts
Posted 14 November 2014 - 09:49 AM
Stolen from Kean on TurboMinis....
#13 GraemeC
GraemeC
  • 7,438 posts
Posted 14 November 2014 - 10:00 AM
and the proper tool from Sykes:
4d05959f-5df2-48d0-be08-d3455f34fd1b_zps
