Fitting An Earth?!?
8 replies to this topic
#1 benmini
benmini
  • 167 posts
Posted 16 February 2009 - 10:21 PM
Hello - I have just brought a mini! there is stereo connections, but when i plug it in there is no power. Halfords were very helpful and tested the head unit and the wiring. They seemed to think that the earth was dodgy. How do I fit a new one, bearing in mind I have little knowledge of minis! (pics would be really useful)
#2 recodes
recodes
  • 61 posts
Posted 16 February 2009 - 10:28 PM
The easiest way is to attach a piece of wire from any part of clean metal on the car, and attach the other end to the chassis of the radio (anywhere on the metal casing)
#3 benmini
benmini
  • 167 posts
Posted 16 February 2009 - 10:38 PM
sounds simple! so - would an areal plugged in work as an earth (my dad said it might?)
#4 recodes
recodes
  • 61 posts
Posted 16 February 2009 - 10:42 PM
Yes as long as the areial is earthed properly !!!
#5 benmini
benmini
  • 167 posts
Posted 16 February 2009 - 10:49 PM
The aerial is attatched to the left wing (metal) so does that mean it is earthed properly?
#6 recodes
recodes
  • 61 posts
Posted 16 February 2009 - 10:55 PM
I would think so, all aerials have to be earthed to work properly so as long as it was fitted right then you should be ok
#7 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 16 February 2009 - 10:58 PM
As far as i know the outer of the ariel plug (the bit that compresses slightly when inserted into the HU) is the earth, and the live is the centre pin, like and RCA audio connection.
Then everything should earth through a black wire coming out the HU...
#8 PMM
PMM
  • 78 posts
Posted 17 February 2009 - 12:44 AM
Depends if the nut securing the aerial has bitten through the paint work enough to make a good connection.
to be honest a proper earth connection should be made as close to the unit as possible and if there is a earth wire then I am always inclined to use it as there is no guarantee that the main circuit board makes direct earth connection to the chassis.
Though the option is there to somehow secure the earth lead to the chassis so it feeds off the aerials.
#9 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 17 February 2009 - 12:47 AM
id always connect the earth the wire from the iso connector just put a screw in the shelf under the dash and then crimp a ring connector to a wire and then chrimp that to the black wire job done
