Amp Problems...
10 replies to this topic
#1 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 17 February 2009 - 11:17 AM
Hi all.
My amp's being a real pain, and I don't understand what the problem is.
It has 2 lights - one for power (green,) and one which says "protect" (red.)
As soon as I turn the ignition on, it will play music absolutely fine, and then after a few seconds it will switch to "protect," and no sound will come out. The stereo however still stays on.
Last time this happened, I thought that it might be a dodgy earth. i replaced it jsut inc ase, but it's still doing it.
Anybody got any other ideas as to what might be the problem?
Thanks in advance
Tom
#2 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 17 February 2009 - 11:50 AM
is normally a bad earth cold be the place where youve attached it does get enough current flow get a multi meter and try and test how much current you get from this earth if its less that 12v it will stop the amp and go into protect mod other option is the amps *melonsed*
#3 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 17 February 2009 - 11:58 AM
Where would you recommend earthing it? It's currently earthed straight through the boot floor. I never had any problems with there before in my previous mini, and the problem hasn't affected this current setup in this mini - only just now...
The bit that confuses me most is that it works for a few seconds, and then goes into protect mode...
Tom
#4 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2009 - 12:15 PM
hi it could be a power problem i got a problem when i got other electrical things on eg headlights the amp just goes straight into protection mode i need a bigger battery and alternator.
cheers
#5 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 17 February 2009 - 12:30 PM
cheers
Hi. it's not this - It doesn't make any difference whether other stuff is on or not and the alternator is perfectly capable... It's not as though i've got a massive set up.
I just want it working, lol...
Tom
#6 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2009 - 12:31 PM
o right sorry couldnt help
#7 PMM
PMM
  • 78 posts
Posted 17 February 2009 - 06:00 PM
I think 1st question should be what amp are you using ?
Protect Led might be indicating something else so its prob best letting us know the amp... Can then check an online PDF manual.
I'd check speaker wiring in the mean time make sure + is + and - is -
#8 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 17 February 2009 - 07:07 PM
Yeah check speaker cables, make sure there not shorting on eachother, or the bodywork.
#9 recodes
recodes
  • 61 posts
Posted 17 February 2009 - 10:27 PM
IF YOU CHECK YOUR SPEAKER CABLES AND THEY ARE OK THEN HAVE THE SUB CHECKED, AS IT CAN ALSO HAVE A SHORT.
#10 level7
level7
  • 108 posts
Posted 18 February 2009 - 08:26 AM
check all rca cables speaker cables and speaker voice coils if they are all ok then one of the fets in the amp is at fault, the indicator is to show either a short on the speakers or a current problem (poor contacts will cause high resistance and as such high amps, amps cause heat not volts) I hope you have a fuse on your battery supply to the amp, I have seen the results of an amp meltdown and it wasn't pretty lol battery acid is a good paint stripper when hot
#11 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 18 February 2009 - 10:42 PM
Yeah it's all fused, i'm not that silly - i've seen things catch fire too ;)
Today, I gave everything a little wiggle and put it all back, and it seems OK for now... pehaps i've fixed it by accident :)
Thanks everyone for your advice, i'll keep it as is for a couple of days and see what happens..
Tom
