Engine Stand
17 replies to this topic
#1 Pooky
Pooky
  • 5,691 posts
Posted 17 February 2009 - 03:21 PM
How essential is an engine stand when building/swapping/setting up an engine?
I'll be swapping my block and head in my 998 and just wondered if it is a part I could do without.
Would one like this Sealey Engine Stand be ok?
#2 MarkGTT
MarkGTT
  • 528 posts
Posted 17 February 2009 - 03:26 PM
I havent used one.. but guess it could be handy. Just built the engine on a bench.
#3 sixwheeler
sixwheeler
  • 500 posts
Posted 17 February 2009 - 05:00 PM
I never bother with one for mini engines.
Sort the engine on the bench (I actually use a work horse thing as it gives you a little more access) and then with the gearbox on the floor, just drop the engine on to it.
#4 Ethel
  • 26,028 posts
Posted 17 February 2009 - 05:03 PM
Or fit the box to the engine as it weighs less.
build up bottom end - fit box - flip over and complete.
#5 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 17 February 2009 - 05:40 PM
i have a engine stand and it makes the job alot more easy and cleaner
ash
#6 MarkGTT
MarkGTT
  • 528 posts
Posted 17 February 2009 - 06:07 PM
ash
depends how dirty your work bench is :P
#7 Pooky
Pooky
  • 5,691 posts
Posted 17 February 2009 - 06:14 PM
Only thing I was thinking is that I'll be timing the cam etc so will need to turn the engine over with the flywheel. Is this possible on a work bench?
#8 m1n1
m1n1
  • 763 posts
  • Local Club: I'm unsociable
Posted 17 February 2009 - 06:34 PM
If you've got the money to spend by all means get one. Honestly ive never used one and do not have the space.
place the block onto the gearbox to do the timing.
#9 mike.
mike.
  • 6,176 posts
Posted 17 February 2009 - 06:36 PM
Thing is they seem like a great idea and pretty cheap but they don't really mount well to an A series without making up some other brackets.
I just made a bench about 2 foot high from a load of old wood. With the engine on that its at a great height to work on.
#10 Pooky
Pooky
  • 5,691 posts
Posted 17 February 2009 - 06:48 PM
Got a pic, so I can get an idea? :P
#11 mike.
mike.
  • 6,176 posts
Posted 17 February 2009 - 06:50 PM
Click the link to my project in my sig. Its a right bogge job with bracing and screws just put in anywhere but as long as it does the job who cares?
The pics on the latest post.
Edited by minimadmike, 17 February 2009 - 06:51 PM.
#12 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 17 February 2009 - 07:06 PM
ash
doesent matter how clean your workbench is , you dont want to but placeing the block face down onto the floor . engine stand you can turn it a round no promblem . i got mine from clark only paid £30 which isent to bad, you can also sell it when your finished .
ash
#13 MarkGTT
MarkGTT
  • 528 posts
Posted 17 February 2009 - 07:51 PM
ash
ash
if i have to explain that it was a joke.. i guess its just not worth it..
#14 mike.
mike.
  • 6,176 posts
Posted 17 February 2009 - 11:33 PM
With the bench i made i bought a piece of laminated wood (like a kutchen top) to use as the top piece. This ways its easily wiped down and cleaned if you were doing a serious rebuild. You'd just have to clean the bench first before and during doing any work to keep it all clean and free from grit and grime.
#15 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 18 February 2009 - 07:56 AM
I have an engine stand with a modified bracket so it can take early and late block types, if i remember i`ll get a pic. makes it much easier to work on as it spins on the stand
