Which Type Of Spark Plugs Do You Reccomend?
17 replies to this topic
#1 mk7cooper
mk7cooper
  • 24 posts
  • Local Club: canterbury mini owners club
Posted 19 February 2009 - 05:18 AM
i have an spi cooper (1998) which plugs does everyone think are better and has anyone played around with gap sizes? i am currently running ngk bpr5es with a .080 gap - are champion better? i know iridium are better but are they ok in an spi mini? - i look forward to everyones thoughts - mark
#2 TimC
TimC
  • 15 posts
  • Local Club: SAMOA
Posted 23 February 2009 - 07:29 AM
On my 96' SPI I've been running the BPR6EIX Iridium-X NGK's. Gapped at .80mm gapped. works perfectly.
#3 mk7cooper
mk7cooper
  • 24 posts
Posted 23 February 2009 - 07:40 AM
do you think it would be ok on a distributorless model? i have read that they dont like extreme plug changes, is that true or just a load of #$%$#@#$$% - cheers for the reply
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 23 February 2009 - 12:02 PM
Dont waste your money on Champion. Rover only ever specified the NGK BPR6E plug, the plug you use is a hotter plug being the BPR5ES
the letters after the BPR6E denote the style of plug S, IX and so on, the imoprtant bit to get right is the BPR6E bit :D
The Iridiums are fine, they just last longer.
Plug gaps are stated as 0.8 to 0.9mm
#5 mk7cooper
mk7cooper
  • 24 posts
Posted 23 February 2009 - 04:19 PM
thanks for that - i will give the iridiums a go then - cheers - mark :mmkay:
#6 sirweste
sirweste
  • 75 posts
Posted 23 February 2009 - 07:18 PM
Recently seen a benifit from fitting NKG BP6ES instead of the recommended resistored version BPR6ES
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 February 2009 - 09:16 PM
But do you now get radio interference as a result?
Because the resistor was simply there to prevent this from happening.
#8 Sprocket
Sprocket
  • 7,266 posts
Posted 23 February 2009 - 10:08 PM
Very true, but what it also does is reduce the resistance of the HT circuit causing the coils to overheat :thumbsup:
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 24 February 2009 - 01:05 AM
Well I've not had any coil problems myself?
#10 mk7cooper
mk7cooper
  • 24 posts
Posted 24 February 2009 - 03:44 AM
hi sprocket - tell me would having the bpr5's possibly cause the car to hunt? - i did have a lot of vacum problems and have finally got the car running nicely, but it hunts at idle, could this be the computer still learning (only done about 100 miles since) or could it be the hotter plugs - cheers mark
#11 Sprocket
Sprocket
  • 7,266 posts
Posted 24 February 2009 - 11:24 AM
Does that make it alright?
:P
#12 Sprocket
Sprocket
  • 7,266 posts
Posted 24 February 2009 - 11:25 AM
I dont know, and you wont know untill you try a set of BPR6E plugs :P
#13 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 25 February 2009 - 01:01 AM
Very true, but what it also does is reduce the resistance of the HT circuit causing the coils to overheat :D
:P
Well my Mini (which I've owned for 15 years) has gone well passed 98,000 miles, starts up first time and runs sweet as a nut. So I don't see those Spark Plugs as being wrong or causing any issues at this stage?
#14 sirweste
sirweste
  • 75 posts
Posted 25 February 2009 - 08:58 PM
putting the non resistored version on mine brought down the emmisions - because they give a bigger spark. But i have done very little milge on them at the moment so i could commentr on thier effect on the coil pack
#15 Cian 'the pain' MPI
Cian 'the pain' MPI
  • 163 posts
  • Local Club: mini-chat.co.uk
Posted 26 February 2009 - 08:11 PM
Im running splitfire split pin spark plugs gave a definate difference
