How Much Diffrence Was There In The 1275 Cooper S Engine And The 1275 Gt?
10 replies to this topic
#1 Alexanderx
Alexanderx
  • 114 posts
  • Local Club: n/a
Posted 19 February 2009 - 04:59 PM
yeah that pretty much my question to eveyone,
get back to me when you can cheers.
Alex.
#2 dan_up850
dan_up850
  • 441 posts
Posted 19 February 2009 - 05:04 PM
brakes and wheels, bonnet, bootlid, and the 1275gt was a clubman not a roundnose.....also did the gt have twin carbs?
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 19 February 2009 - 05:09 PM
Well Unless your one of the lucky one's the very early 1275GTs were fitted with the last of the Cooper S 1275s but there wer'nt many.............. :thumbsup:
the main Differance's are Cooper S engines had 11 stud heads, tappet chest covers and a plate rivited to where the petrol pump would be located and all the internals are different EN40B crank being the main difference.......... :)
#4 Alexanderx
Alexanderx
  • 114 posts
  • Local Club: n/a
Posted 19 February 2009 - 05:20 PM
cheers for the replys guys, because i've been looking into getting a 1275 gt and was wondering weather it was worth getting one of them,
or holding out for a 1275 coopr s or just a 1275, what would you recomend?
ta alex.
#5 Asphalt
Asphalt
  • 2,173 posts
Posted 19 February 2009 - 05:21 PM
Or to make it short: two totaly different engines. :thumbsup:
The fuelpump hole isn't riveted, but closed by the casting :)
#6 0000
0000
  • 15 posts
Posted 19 February 2009 - 06:46 PM
Get a 1275 GT i've got one and i love it as it has been tuned slightly and is really nippy
#7 Alexanderx
Alexanderx
  • 114 posts
  • Local Club: n/a
Posted 19 February 2009 - 07:04 PM
points noted, how well do 1275gt fi in standard minis i mean will i need to make any mods to my 998 mini mayfair?
thanks again.
alex.
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 19 February 2009 - 11:07 PM
The fuelpump hole isn't riveted, but closed by the casting :(
Cooper S blocks did not have a hole for pump and it had a alluminium plate reading 1071 rivited to it..........I know I have one.................. :ermm:
#9 Asphalt
Asphalt
  • 2,173 posts
Posted 19 February 2009 - 11:32 PM
Yeah, what I said... Closed fuel pump hole (by casting, not by a riveted plate) :(
Maybe it/I was a bit missleading...
Only know the rivetet tag as flanking the raising where the fuel pump would sit. Like this:
But well possible the location of that plate differed between the different 'S' engines :thumbsup:
by the way: that tag was not solely used on Cooper S engines, I've seen in on 1275GT engines too :o
And I think on a 950
Edited by Asphalt, 19 February 2009 - 11:33 PM.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 February 2009 - 07:23 AM
GT engines and 1275 S engines are completely different engines in terms of parts and specification...
They had different blocks, cranks, rods, pistons, cam, head, valves and rockers for a start.
#11 Jammy
Jammy
  • 25,397 posts
Posted 20 February 2009 - 08:52 AM
It depends, do you want an 'S' or GT engine for certain sentimental reasons? You'll pay a hefty premium for an 'S' engine, but you could modify a 1275 to similar or greater engine output for less money.
