7.5 Or 8.4?
7 replies to this topic
#1 uksurvivor
uksurvivor
  • 174 posts
Posted 19 February 2009 - 09:15 PM
Being offered as Cooper S discs but I'm not so sure.....
Any help much appreciated - already been burnt buying discs on the interweb once......
Andy
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 19 February 2009 - 09:21 PM
8.4"
#3 uksurvivor
uksurvivor
  • 174 posts
Posted 19 February 2009 - 09:37 PM
8.4"
How can you tell - whats the giveaway????
#4 backstreetclassics
backstreetclassics
    Previously known as minidan07
  • 1,898 posts
  • Local Club: essex mini club
Posted 19 February 2009 - 09:39 PM
the drive flange gives it away nxt time yr down the yard ask kell to show you the diffrance
#5 Pooky
Pooky
  • 5,691 posts
Posted 19 February 2009 - 09:41 PM
7.5" discs are only slightly bigger than the flange
see here
The discs in your photo are considerably larger
#6 uksurvivor
uksurvivor
  • 174 posts
Sunken bolts in the drive flange?
#7 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 19 February 2009 - 09:42 PM
One way is the Cooper S flange does not have the deep 4 holes
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 February 2009 - 09:49 PM
Yes that's the real giveaway. The Cooper S/GT flange is held to the disc by small countersunk Pozidrive screws rather than the large hex head bolts used in the 8.4 flange. The S/GT wheel studs are set into the disc itself and just run through the flange whereas the 8.4" studs are set in the flange. This way you can tell whether it's a real 7.5" set or a machined down 8.4" (which do exist for use with some alloy caliper sets).
