Bt Home Hub
Posted 20 February 2009 - 10:04 AM
I have a BT Home Hub at home. My broadband is wired from the HH to my desktop PC. I am trying to use my laptop and pick up a broadband connection wireless in the house. It find the HH but cannot connect as there seems to be a protection on the wifi connection.......
Questions:
1. Does the above make any sense atall?
2. If so, how do i get rid of this protection so I can access tinternet from laptop?
Cheers, Wickett
Posted 20 February 2009 - 10:17 AM
This key will be several pairs of numbers/letters strung together, and may be found on the bottom of the router or in the router settings page (which you will have to access using a wired connection to the router and using your internet browser).
In windows, try to connect to the network, and it should prompt you for the key if you are connecting for the first time. Choose the key type, enter it, and you should be connected!
Posted 20 February 2009 - 10:24 AM
hope this helps
-ad-
Posted 20 February 2009 - 10:29 AM
Ill give this a whirl when i get home tonight!!! Thank you kind squires
Posted 20 February 2009 - 10:34 AM
Posted 20 February 2009 - 10:47 AM
Posted 20 February 2009 - 12:56 PM
Posted 20 February 2009 - 01:01 PM
I have found that if you are using Vista with a Home Hub that you need to disable the Vista firewall before trying to conect to the Home Hub wirelessly then turn it back on once successfully connected.
Posted 23 February 2009 - 08:17 AM
Cheers all for help,
Wickett
Posted 23 February 2009 - 08:33 AM
Why do so many companies still use WEP as the default encryption? It's ridiculous.
Posted 23 February 2009 - 09:00 AM
Hooray!
Couldn't agree more, I've heard it takes about 10mins to beat the standard WEP encryption on a BT Homehub..........I'm sure experts are a lot faster!
