got a set of magnolia smiths gauges,(oil temp,volts and clock)
You said you've hooked up the clock. Hooking up the volt meter will be similar. Use the same earth connection as the clock and connect it to one of the volt meter's terminals. The second volt meter terminal will need to be connected to any switched 12V supply on the fuse box. If this is a Smiths gauge, it doesn't matter which terminal is earth and which is "hot". If this is not a Smiths brand gauge the polarity may be important and this is usually noted on the back of such gauges.
Oil temperature gauge? Really? Oil temperature is nearly useless information. Water temperature is much more useful to know. If it really is oil temperature you need to buy one of two adapters for it. One option is an adapter for the spin-on oil filter head. It will position the sending unit in the oil flow. The second option replaces the external oil pipe on the front of the engine block with a set of flexible hoses and a housing for the temperature sending unit. Both options are expensive.
When you are wiring MOST Smiths electrical gauges (excluding clocks and volt meters) you have to supply them with a regulated 10V supply. Do a search here for "voltage stabilizer". There have been many threads on this board (including one within the past two weeks) that discuss the role of the voltage stabilizer. Succinctly, you will connect the input "B" terminal of the stabilizer to a switched 12V supply, provide its case with an earth connection, and connect the stabilizer's output "I" terminal to one of the terminals on your electric Smiths gauge. The other Smiths gauge terminal receives a wire from the sending unit. One voltage stabilizer is OK supplying 2 or 3 gauges.
