Steam Clean?
6 replies to this topic
#1 minimotor_JD
minimotor_JD
  • 334 posts
Posted 24 February 2009 - 03:34 PM
Rover Mini City E
1991
Steam Clean Engine Bay
I got some GUNK to clean my engine bay, in doing so my next door neighbor saw me and gave some advice, he said that he steam cleaned his engine bay (he has a VW of some sort) anyway i had a look and it looks fab.
Any ideas if i shld do this and weather it wld screw up the electronics?
Edited by minimotor_JD, 24 February 2009 - 03:34 PM.
#2 tuktuk
tuktuk
  • 1,231 posts
Posted 24 February 2009 - 03:35 PM
i leave my car running when i do this :)
works really well...
#3 chappy
chappy
  • 1,253 posts
Posted 24 February 2009 - 03:37 PM
Rover Mini City E
1991
well the steam will condensate when it cools on things, so just clean the engine block, they have a hose on it which is pretty direct so wouldn't have any over spray,
but it really depends on how dirty your engine bay it, if its really sludged up then steam isn't gonna shift it, just good old elbow grease :)
sam
hope it helps
#4 sixwheeler
sixwheeler
  • 500 posts
Posted 24 February 2009 - 04:28 PM
If it is really stodged up, then a steam cleaner is the very thing that you want. NOT a cold water pressure washer, but a steam cleaner - cuts right through it leaving it 'squeeky clean' if that is what you are after.
That said, a plain old pressure washer will cut through the muck and leave an oily surface and dirty oily marks - which can be a good thing; the steam cleaner does get it very clean, but then it is so clean that it will start to rust....
I gave up using gunk years ago, pointless stuff. Get a pressure washer of somewort on it. Leave the engine runing and the heat from the engine will dry it out. Worst the generally happens (as long as you are being careful) is that you may need to dry the cap and the leads off.
Edited by sixwheeler, 24 February 2009 - 04:30 PM.
#5 minimotor_JD
minimotor_JD
  • 334 posts
Posted 24 February 2009 - 10:10 PM
Its really dirty,lol, I dont think it has been cleaned ever :P, i'm so disappointed whenever i open my bonnet :D, there is lots and lots of grease everywhere, already gone through half a bottle of Gunk.
#6 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 24 February 2009 - 10:54 PM
Due to a recent oil pipe failure my engine bay was stinking, I managed to get the oil off using gunk and a hose pipe. I was suprised to find that the 15 years of filth that was on the engine block was just falling off with the hose pipe. I did spray 1 and a half bottles of gunk and one can of brake and clutch cleaner over it, it's now spotless. And all I did was spray on cleaning fluid and then rince off, I left it on there for around 5 minutes aswell.
#7 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 February 2009 - 11:03 PM
Best method by far that i have been using recently is (this is without the engine in the car) A 99p can of choke/carb cleaner, and a toothbrush.
Brings most things up bristol fashion. messy though,
