Made a start the other day and got down to making the speaker pods for the front footwells. I'm going against my better judgement and using all Fusion equipment, since its my girlfriends car and she wanted the green to match the car...
Plans are as follows:
Up front there will be a set of 5.25in components, with the mid ranges in pods under the dash rail and the tweeters ontop of the dash, tucked in either side of the top dash rail.
The back shelf will comprise of a set of 6.5in coaxials in a fibreglass install, and most probably be run off the headunit.
These plans are a definate, and I'm actually about half way done, but on top of this I want to build something in the boot aswell.
I was thinking of an amp rack on the rear face of the firewall and an mdf boot floor. The reason I wanted to build an amp rack is when I opened up the components, the crossovers are like mini versions of the fusion amplifiers!! Soooo cool! So I just have to get an amp to match the little crossovers, then mount them all together in a nice enclosure.
Will probably have to do loads of shielding to the speaker cables though, since the amp will be powering the front speakers from the back, so plenty of space to pick up distortion along the way
Heres some pics of bits and progress so far:
Heres the stuff thats going in, looks pretty and I know its not gonna be audiophile perfect, but it'll do the job nicely. Note the awesome crossovers!!
They look just like this amp only smaller:
Made a load of mdf rings, most of them for the front pods, then Araldited them together, I swear its stronger then fibreglass now lol
Then rather than self tap into the pods themselves, I got a bracket to go on the back with a bolt glued to it sticking out the top. With a penny washer it fixes to the bottom dash nicely, there is a very small amount of movement, but nothing major and not worth drilling a hole in the car to solve.
Here they are fitted and with the speaker resting in it, I've yet to make the other side or drill holes to screw the speaker into, but I got distracted lol
Like I said, still a bit of work to do on them, but I got sidetracked making the rear shelf!
The idea is to have a nice fibreglass install with two coaxials in it, painted the same colour as the car. So I knocked up yet more MDF rings...
And made a fibreboard base shelf and screwed two of the rings to it, followed by the upper rings on the supports I made up.
Actually that step was preceded by fiddling for ages in the car to make sure it wasnt going to foul the back seat or the window!
The glue is currently setting on the skeleton, but I have to work all weekend so its unlikely to be touched now until monday
Whats everyone think?
