Hello folks,
Anyone got any pics a good place to put the return pipe on the fuel tank?
Doing one for my friend.
Cheers Ali
Where to put return pipe on fuel tank?
Alburglar
, Aug 20 2005 05:57 PM
9 replies to this topic
Posted 20 August 2005 - 05:57 PM
Posted 20 August 2005 - 10:46 PM
Buy a fuel injection tank. Everything should be there that you need including a submersed pump :cheese: Otherwise I think the top is as good a place as any, though welding a fuel tank is a bit dodgey unless its been steam cleaned on the inside
Posted 21 August 2005 - 06:36 AM
"T" peice on the breather ?
Posted 21 August 2005 - 01:25 PM
Most people just fit an MPI fuel tank as it has all the bits on it you need and the diameter for the size of the fuel pipes is big enough!
Posted 22 August 2005 - 01:32 AM
I will be converting a normal tank as you can't give the pesky things away,
Where is the return situated on an MPI tank. I won't have a car to offer it up to and I want to make sure I'm not gonna put it somewhere so the tank won't fit
Posted 22 August 2005 - 02:10 AM
i dont have a return on my tank, just T pieced it back into the feed line between the tank and pump.
Posted 22 August 2005 - 02:38 AM
Oh I see. Yeah that makes sense
Posted 22 August 2005 - 05:04 PM
It is at the top. See the picture below, the flat plate on the right bolts to the tank at the top both feed and return can be seen along with the wring plug for the fuel pump. All in all a neat little package.Where is the return situated on an MPI tank. I won't have a car to offer it up to and I want to make sure I'm not gonna put it somewhere so the tank won't fit
Which tank have you got, the plain ordinary one or a fuel injected one as your statement is a little unclear
Posted 22 August 2005 - 08:52 PM
if you have a return brazed in put it in as high as possible in the tank
also bare in mind the feed has to be smaller than the return if possible
Posted 22 August 2005 - 09:42 PM
It is a standard tank for non-injected
