1985 998, standard, with a 74 degree thermostat
what sort of spark plugs do i need? there are too many to choose from and far too confusing to a muppet
Spark Plugs
wakkoboi
, Mar 01 2009 03:52 PM
6 replies to this topic
Posted 01 March 2009 - 03:52 PM
Posted 01 March 2009 - 04:09 PM
BP6ES,GSP163,N9Y or equivalent
Posted 01 March 2009 - 04:12 PM
whats the difference? just out of curiosity?what makes a good spark plug good etc?
and thanks for your reply
Posted 01 March 2009 - 05:08 PM
You will seldom find a 'bad' spark plug,.. but it is easy to find a plug that is 'bad' for your set-up. Champion and NGK are probably the most popular makes.
Same as any other product, the quality control of production, the materials used to build it and the price!!!
Very basically you want a Copper Core on a Spark plug rather than a steel one as it will draw the heat away from the tip faster...
Or to cut a long story short. Buy NGK
or use the search function, plenty of spark plug topics...
Posted 01 March 2009 - 05:29 PM
The 3 I listed are just different manufacturers part numbers. Most of the manufacturers will have techie info explaining their own numbering system on their site. Apart from plugs that have built in resistors (useful for suppressing interference with radios and electronic engine management) the major difference is a plug's operating temperature. A performance engine will like a plug that dissipates heat well to avoid detonation but if a plug is too good at dumping heat it will get sooted up during warm up and may never get up to temperature if the engine is just bimbling about on part throttle for a few miles. If the soot isn't burned off the plug will eventually foul 'n stop firing.
Posted 01 March 2009 - 09:30 PM
ok thanks again
