Bad Idling, Very Jumpy And The Engine Bounces Around...
6 replies to this topic
#1 kitroxin
kitroxin
  • 494 posts
  • Local Club: Celtic Minis
Posted 02 March 2009 - 12:36 PM
Hello, just wondered if anyone on here has any ideas as to what i should check to solve my 1992 spi cooper's idling problem, as i said in the title it isnt idling smoothly at all and the engine appears to be jumping all over the place even though the mountings are tight..
any suggerstions?
cheers, kit
#2 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 04 March 2009 - 02:08 PM
H ave you checked over all the basics..sparkys, ht's etc also worth look over is the two vacum pipes that go into the back of the throttle body that also go to the little black box nxt to it..could even be a blockage in the fuel filter
#3 J0N0
J0N0
    Starting My Mini Up
  • 3 posts
Posted 11 March 2009 - 05:17 PM
Hello, just wondered if you had solved the problem yet? as mine is doing the same thing, thanks
#4 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 11 March 2009 - 05:20 PM
check that the black pipe has not seperated from the ECU
#5 J0N0
J0N0
    Starting My Mini Up
  • 3 posts
Posted 12 March 2009 - 10:09 PM
Sorted thanks :D
#6 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 12 March 2009 - 10:11 PM
Perhaps you could post up the way you fixed it. This way when people use the search function to search for similar problems your post will come up. Help us help others!
#7 J0N0
J0N0
    Starting My Mini Up
  • 3 posts
Posted 13 March 2009 - 10:13 AM
Ok, well i checked the black pipe from the ecu as suggested, i followed this pipe and it led to a small black box which i think is the fuel trap, the pipe was fine but i realised there was nothing else connected to the box, allthough there was like a small black pipe next to the elbow wich looked like it should have something on it. I had a look around and found a pipe coming from the back of the throttle body that wasent going anywhere so i put this on the fuel trap, and it the engine ran smooth for the first time in weeks >_<
