Primary Gear Oil Seal
13 replies to this topic
#1 Pauly
Pauly
  • 4,213 posts
Posted 02 March 2009 - 02:26 PM
Hi guys,
Do you need the special tool to fit the primary gear oil seal??
Whats the best way to fit them without the tool so as not to damage them?
Also do engine to gearbox bolts have to be torqued?? Ives just tightened as hard as possible with my little spanner.
Thanks.
Paul.
#2 Brigbeale
Brigbeale
  • 287 posts
  • Local Club: Bournemouth Mini Club
Posted 02 March 2009 - 02:43 PM
Most people wrap insulating tape over the splines on the crankshaft to avoid damaging the new seal.
The engine to gearbox casing bolts are shown in the Haynes manual as being torqued to 6ft/lbs each.
#3 Pauly
Pauly
  • 4,213 posts
Posted 02 March 2009 - 03:19 PM
Do you put the seal into the transfer case first, then fit it onto the engine?
#4 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 02 March 2009 - 06:09 PM
a standard 1275 pistons is exactly the right size for pushing the oil seal into the housing. and yeh tape to cover the splines when its installed
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 02 March 2009 - 11:00 PM
Shows that in the haynes but I didnt, was also told by someone else put case on first then seal after using either tape method above or using special tool.
I'd recommend getting the tool, makes it so much easier.
#6 daveeeeee
daveeeeee
  • 684 posts
Posted 02 March 2009 - 11:33 PM
i pulled the primary gear out first, put the seal on the gear, then used a tool for it, but i've used a glass jar before, worked fine but not recommended incase of injury ^^ *disclaimer*
think minisport do the tool?
#7 Pauly
Pauly
  • 4,213 posts
Posted 04 March 2009 - 04:07 PM
Still trying to fit this :) .
When I try to tap it in on the one side of the seal the other side pop's out.
Paul.
Edited by Pauly, 04 March 2009 - 04:07 PM.
#8 daveeeeee
daveeeeee
  • 684 posts
Posted 04 March 2009 - 06:12 PM
http://cgi.ebay.co.u...2e2dbc2ff3aaebf
i actually managed to borrow one from my local unipart, at a cost of £15 or something :lol:
Edited by daveeeeee, 04 March 2009 - 06:15 PM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 March 2009 - 06:21 PM
To install the PS with the transfer case attached to the engine you will need the special tool... or equivalent pipe. Not only is it important to get the seal in far enough it is also VERY important that it is square to the rotational axis of the primary gear, if it is not then it'll pee oil almost from the first start.
#10 Pauly
Pauly
  • 4,213 posts
Posted 06 March 2009 - 08:58 AM
Ive finally got the seal in, but just need to know, does it sit flush with the transfer case or is it slightly recessed??
Thanks.
Paul.
#11 Pauly
Pauly
  • 4,213 posts
Posted 06 March 2009 - 06:24 PM
BUMP.
#12 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 06 March 2009 - 07:49 PM
i've always done mine flush and never had a problem, i just hammer them in with a rubber mallet.
#13 Pauly
Pauly
  • 4,213 posts
Posted 06 March 2009 - 08:21 PM
Cheers nick :P.
Paul.
#14 mini mayhem
mini mayhem
  • 307 posts
  • Local Club: Mini Club Of Ireland
Posted 26 March 2009 - 06:20 PM
nice thread
