Hi
Can anyone please help me, have had to change the engine in my mini and we have got a 1275 Carb engine, but want to put it into a SPI min.
Is there a way to fit the flywheel sensor which should be near the starter motor?
Does that all make sense???
1275 Carb To Injection Help Needed
chrisevans35
, Mar 05 2009 08:26 PM
2 replies to this topic
Posted 05 March 2009 - 08:26 PM
Posted 06 March 2009 - 01:48 AM
You have to change the transfer housing for an injection one with the mounting holes for the sensor. you have to use the flywheel from the injection engine also. Or, not so cheap a fix, is to fit a trigger wheel onto the crank pulley and make up a bracket to mount the sensor, extend the wiring from the ECU and then correctly set up the missing tooth location on the trigger.
would be easier to change the transfer housing and flywheel
Posted 06 March 2009 - 08:10 PM
Hi Sprocket
thank you very much for coming back to me.
