Raising Ride Height Using Washers
who_loves_the_mini?
, Mar 07 2009 09:03 PM
8 replies to this topic
Posted 07 March 2009 - 09:03 PM
Ive just fiited my new wheels and they are rubbing on the front so need to raise the ride height, I will be ordering hi-los, new cones etc this week as I dont think they have ever been changed, but Im not able to drive the car at the moment as its too low.
Can anyone give me a quick run down of the process of of fitting washers? Also what is the maximum you can fit? I know the ratio is 3:1 at the front and 5:1 at the back.
Posted 07 March 2009 - 09:20 PM
im probly wrong, but i saw a pic in mini mag, and the bloke had taken the trumpets out, and put washers between the trumpet and the knuckles, if you are fitting hi los i wouldnt bother putting the washers on the back, shouldnt rub on the back anyway! also, if your fitting hi los on the front, might be worth putting in new rubber cones, as this will lift the height a bit too, as they could be past their best if they havent been replaced before!
Edited by The_Mistro, 07 March 2009 - 09:22 PM.
Posted 07 March 2009 - 09:21 PM
compress rubber
remove alloy trumpet
place washer(s) between knuckle joint and alloy trumpet
put back together
so a 5mm washer will raise you up 15mm
put back together
Posted 07 March 2009 - 09:24 PM
Excellent, thanks Mr Bungle. Do you know the maximum thickness of washer you can use?
Posted 07 March 2009 - 09:26 PM
from memory the shaft on the knuckle is about 1/2 inch long
remembering you need a bit to locate in in the trumpet
Posted 07 March 2009 - 09:33 PM
Excellent, I dont think it will need raising that much, hopefully it should be ok with a 5/6mm washer
Posted 07 March 2009 - 10:12 PM
This may seem a daft question but what size are the new wheels?Are they rubbing over bumps or when applying steering lock?
Widths of 5.5 and above normally cause problems fouling on the arches and they will need to be cut at the front of the front wheel arch.Appologies if im stating the obvious but you never know.
Cheers Ross.
Cheers Ross.
Edited by rosco454, 07 March 2009 - 10:12 PM.
Posted 07 March 2009 - 10:22 PM
The wheels are only catching on the actual arch so hoping by raising it slightly it should clear them. The wheels are 6" wide and if we do have to cut the wings then we will, but hopefully raising will sort it as it did on my last mini.
Anyone know the diamater of washer needed?
Posted 08 March 2009 - 02:16 PM
If you are getting the parts to do the job properly in a week or two, why not just fit your old wheels back on for a few days - the amount of work and aggro to put in the washers just for a couple of weeks isn't worth it!
JR
JR
