Idle Speed: 839-906
Stepper Position: 39 Steps
Vacuum Lvl: -148mmHg
Coolant Temp: 97 C but eventually went all the way up to 110 C and the electric fan never kicked on
Throttle Pot: 0.5V
Purge Duty: 58%
Oxygen Sensor: 646-651MV (bounces around with lowest number 646 and highest 651)
Ignition Advanced: 9.0-27.5 (this too bounces around with set pattern, lowest i saw was 9.0 and the highest 27.5 with all kinds of number in between)
Oil Temp: HOT
When I tried using the "Tune" feature i get the message "Engine has a fault this test will be aborted" any ideas????
also when i first start up the ACT it askes me if i want to use CUDOS. what is that exactly??
