Performance Upgrades...
Posted 10 March 2009 - 01:15 PM
So after sourcing a stage 1 head (or stage 2, he's not sure) from munnracing, and a Maniflow exhaust and manifold also from munnracing, we went about fitting them. Turns out, there was a good 4" hole in the top of my original backbox, the manifold was perhaps half the size of the new one, and the old head had a cracked valve!
Now, after fitting these, we eventually got it running. Drove home, it was fine. Then it suddenly dropped to 3 cylinders, and after drying was of the plugs (which was soaked) it ran normal, but after literally a few seconds dropped back to 3. We then changed all the plugs, and it seems to be alright for now, but there is an aweful amount of smoke coming out of the back, which sticks of petrol. Could the mixture, which will hopefully be adjusted asap, cause the 3rd spark plug to get wet and drop to 3 cylinders?
Thanks, Ben
Posted 10 March 2009 - 01:20 PM
Posted 10 March 2009 - 01:21 PM
No, this is what i'm asking. It will be rolling roaded asap, but as a temp. fix, will a simple mixture adjustment sort this out?have you tuned the car since you added the mods? as this may be why
Posted 10 March 2009 - 01:41 PM
It’s also possible as the engine has been played with and your previously lack of performance problems (my standard 998 can do up to and slight more than a ton if pushed) could be down to a weak spark not being able to burn off all the fuel/air mix, so might be worth going through and checking the ignition system.
Posted 10 March 2009 - 01:50 PM
As for uprating the head, not much point unless your uprating the cam at the same time.
Only things needed for a stage 1 are; exhaust, manifold, air filter, and carb needle.
Posted 10 March 2009 - 02:09 PM
Ingnition wise, all HT leads and plugs were changed, and i'm going to get an electronic ignition off a friend tonight and fit that also.
What cam would you recommend to pair with the head then? Wasn't planning on doing so, but if it was get more performance out of the head, it may be worth doing before a rolling road.
Posted 10 March 2009 - 02:11 PM
hope that helps....
Posted 10 March 2009 - 02:14 PM
Posted 10 March 2009 - 02:23 PM
Stage 1 rich needle, and a Pipercross filter have been added also. But i've taken the rich needle back out as it was running too rich, but it still hasn't quite sorted the problem.
If you tried to adjust the mixture with the stage/richer needle then the settings will be out once you replace it back with the original, you can try setting the mixture up with a either a co tester or a colour tune kit which will be a lot better than guess work.
Posted 10 March 2009 - 02:26 PM
Posted 10 March 2009 - 03:36 PM
After refiting the head, did you reset the tappets?
Posted 10 March 2009 - 05:23 PM
This then? As i was looking into 1.5 roller rockers also.
http://www.swiftune....ghlift-kit.aspx
1.5 rockers are overkill on a 1275 let alone a 998!!
Pressed steel rockers is what you need to look for. Their good enough for upto 150 bhp!
As for cam, get a Kent, either 266 or 276. Kent do the best cams about for the a-series, no doubt about it.
Posted 10 March 2009 - 06:26 PM
3 different sets of spark plugs have been used, and after running fine for 2hours or so, it dropped back to 3 cylinders. Just tried some performance leads i've nicked from a mate to see if it was that particular lead getting warmed up and not sparking enough.If its just one plug that is geting fouled up I would say its not a fueling issue, maybe that plug has weak spark causing it to get fouled and no combust fuel. Adjusting the mixture to compensate for one plug being wrong will do nothing, if it was a fueling issue all of the cyinder would be effected. I would check your ignition system if I was you.
Posted 10 March 2009 - 07:07 PM
Posted 10 March 2009 - 07:56 PM
