Tomtom Sat Nav
4 replies to this topic
#1 GoonerMini
GoonerMini
  • 420 posts
  • Local Club: SMAG Southend Mini Action Group
Posted 11 March 2009 - 01:46 PM
I have installed in my 2002 Seven a cigarette lighter wired up to the useless brake fluid switch as has my firend in her 1999 Sport. My cigarteet lighter works fine, not that I need that, but as soon as the TOMTOM is plugged in the fuse blows. This also happens to my friends car with my TT but not with her own. My TT also works fine in my MAZDA and in my sons Escort. Any ideas?
#2 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 11 March 2009 - 02:07 PM
to be honest sounds like the Tom Tom is drawing too much power - does it have a fuse in the charger connection ?
On an aside im not sure itis a great idea to wire the cigar lighter into the brake switch - prob best to take a live direct from the fuse box and in-line fuse it.
#3 Jammy
Jammy
  • 25,397 posts
Posted 11 March 2009 - 02:12 PM
I was thinking about the same with the brake switch. The brake test switch is incredibly useful. How else would you know of a brake leak? If the circuit is properly maintained then it could be a lifesaver. Also, if an MOT tester is familiar with Minis then I believe it could well be a failure point if it doesn't work.
On top of that, I'm pretty sure the wiring used for the brake fluid level test circuit will not have been designed to carry the current needed for a cigarette lighter or a TomTom. To me it seems very risky, and has potential to cause an electrical fire.
#4 GoonerMini
GoonerMini
  • 420 posts
Posted 11 March 2009 - 02:23 PM
Thanks I will change the power source. I only did it this way as my friend has no problems with hers.
#5 GoonerMini
GoonerMini
  • 420 posts
Posted 11 March 2009 - 02:25 PM
One more question, what value fuse should I use?
