Powermax Pistons 20950 Help Need Rings!
4 replies to this topic
#1 jkjaxor
jkjaxor
  • 331 posts
Posted 12 March 2009 - 08:21 PM
hi all,
have got a set of powermax pistons with the code 20950 stamped into them,
there for a 998 with a +20 overbore, thing is one of the rings has snapped and i need to get a new set but cant find any for this piston, does any one know of any that will fit,?
cheers for any help
#2 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 12 March 2009 - 11:25 PM
Ive had trouble trying to find a ring before, the only real way to get one is to find someone whos done the same thing and bought a set, then buy some off them.
#3 jkjaxor
jkjaxor
  • 331 posts
Posted 13 March 2009 - 12:28 AM
its not the single ring im having trouble finding, its the whole set,
my pistons dont seem to be listed on most sites and on mini speed they are out of stock >_<
thanks for trying though.
#4 mini_mad69
mini_mad69
  • 5,417 posts
Posted 13 March 2009 - 01:50 AM
Oh ok, I typed in my piston part number into google, then pressed the shopping tag and it came up with a few results, you could try that. Try contacting powermax directly and ask where they may be available.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 March 2009 - 08:25 AM
first measure the ring lands on the piston, this will give you a better idea of what rings you are after... you may find that std +20 rings will fit..
eg the top two may be something like 1.2 or 1.4mm, and the oil scraper 4mm
