Well, it's quite simple really.
A scatter cam plays about with the timing of cylinders in pairs. This is in order to acheive greater seperation between the strokes of the pairs of cylinders that share inlet tracts, to hopefully eliminate the charge distribution problems caused by the siamesed ports. So it moves two strokes further apart and two closer together. It's kind of like having a five cylinder engine with one cylinder removed, in that there is a big lump of the cycle where there is no power stroke. But this is more than made up for by the slightly overlapping power strokes happening elsewhere in the cycle which add huge torque and power gains, coupled with the better fuel charge distribution (which basically means you can run a much less flow efficient inlet manifold without such a big penalty, something like a short neck single Weber for example) which all in all means you can get buckets of tractable power out of a scatter cam engine.
The downside is that it's rough. It's really rough at a relatively low (or normal for street use) idle speeds, and basically quite violent for the crank throughout the range as the smooth power delivery is interupted. This is really bad for a three main bearing engine like an A series. You need some proper crank retention (you can't actually buy the all steel multi bolt full main cap set off the shelf any more but it was great for this application) and really good harmonic damping to try to keep the crank straight and stop it failing. Ultimately main bearings and thrusts won't last as long in these motors as they would otherwise.
They are also expensive as it's not possible to grind them from an existing cam due to the unusally wide timing, so a brand new full circle core unit has to be employed which is costly. They must be timed in really well and other mods need to be performed at the same time in order to make them usable. You couldn't just stick one into an engine which had not been assembled with one in mind.
Pretty much a straight race cam.
Edited by Dan, 24 August 2005 - 06:26 PM.
