Does Anybody Know This Engine Number?
14 replies to this topic
#1 steble
steble
  • 750 posts
  • Local Club: chichester mini club
Posted 17 March 2009 - 06:13 PM
its a metro 1275 engine but i want to know what from. the number is 12H9D09 ****** does anybody know or know where i can find out would be a great help
kind regards
steve
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 March 2009 - 06:18 PM
http://www.guess-wor...ical/engine.htm
but the one you have there is not a 'normal' engine number
12HD09*** is but not 12H9D09
Edited by GuessWorks.co.uk, 17 March 2009 - 06:20 PM.
#3 steble
steble
  • 750 posts
Posted 17 March 2009 - 06:24 PM
this was good, but is there anyway of knowing what metro it was from???
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 March 2009 - 06:28 PM
What do you want.. colour, registration ???
:shy:
Basically a bog standard 1300 metro
Edited by GuessWorks.co.uk, 17 March 2009 - 06:29 PM.
#5 steble
steble
  • 750 posts
Posted 17 March 2009 - 06:36 PM
:shy:
what i wanted to know was, was it from a city, gta, mg etc etc???? i was looking up the metro specs and they all have different BHP ranging from about 60 to 75 and lots of different types of metro had different BHP's
#6 Pauly
Pauly
  • 4,213 posts
Posted 17 March 2009 - 06:41 PM
Take it with a pinch of salt, main difference is mg & austin metro engines, mg engines having a hotter cam.
Paul.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
well it's none of the above...
It's a straight bog std metro, nothing special, probably an HL, City or limited edition based on said models, it's not a GTa, VDP, MG, Turbo, HLE or City E
and it's not unleaded either...
Edited by GuessWorks.co.uk, 17 March 2009 - 06:43 PM.
#8 steble
steble
  • 750 posts
Posted 17 March 2009 - 06:52 PM
its def unleaded i been using it for nearly a year lol
best match i can find is a HLE which has the code of 12HD09
#9 steble
steble
  • 750 posts
Posted 17 March 2009 - 06:54 PM
you wont believe this, the HLE is the only one the parkers guide doesn't have the power for
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 March 2009 - 06:56 PM
A+ specification 50bhp @ 5000rpm 66lb ft @ 2600rpm 1992-2000: Mini Sprite / Mayfair
61bhp @ 5550rpm 61lb ft @ 3000rpm 1990-91: Mini Cooper
61bhp @ 5300rpm 69lb ft @ 2950rpm 1980-84: Morris Ital
62bhp @ 5600rpm 72lb ft @ 3200rpm 1980-82: Austin Allegro
63bhp @ 5700rpm 70lb ft @ 3900rpm 1991-1996: Mini Cooper 1.3i / Cabriolet
63bhp @ 5500rpm 70lb ft @ 3000rpm 1997-2000: Mini Cooper 1.3i (TPi)
63bhp @ 5650rpm 72lb ft @ 3100rpm 1980-90: Austin Metro
64bhp @ 5500rpm 73lb ft @ 3500rpm 1983-85: Austin Maestro HLE
68bhp @ 5800rpm 75lb ft @ 3500rpm 1983-93: Austin Maestro
68bhp @ 5600rpm 75lb ft @ 3500rpm 1984-89: Austin Montego
72bhp @ 6000rpm 73lb ft @ 4000rpm 1982-89: MG Metro
73bhp @ 6000rpm 73lb ft @ 4000rpm 1989-90: Metro GTa
77bhp @ 5800rpm 80lb ft @ 3000rpm 1991-2000: Mini Cooper S 1.3i
78bhp @ 6000rpm 78lb ft @ 3250rpm 1990-91: Mini Cooper S
93bhp @ 6130rpm 85lb ft @ 2650rpm 1983-89: MG Metro Turbo
96bhp @ 6130rpm 1989-90: Mini ERA Turbo
#11 steble
steble
  • 750 posts
Posted 17 March 2009 - 07:03 PM
looks like i got a 64BHP one then
i was hoping it would be a gta, sport, VP or GS for obvious reason there all 72BHP
#12 rudeboy
rudeboy
  • 101 posts
Posted 17 March 2009 - 07:05 PM
i just put my engine number into your site and although my documents say its a 1275 your site tells me its a 998,, hmmm strange one, some more investigation needed, is there anything obviously different on a 1275 to a 998 that i could check in the morning...
#13 steble
steble
  • 750 posts
Posted 17 March 2009 - 07:06 PM
someone correct me if i'm wrong, but i think its only a 1275 if the engine number starts 12H
#14 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 02 April 2009 - 01:53 AM
A 1275 has 2 core plugs on the end of the block and probably not have tappet chest covers on the back of the engine. Unless if im not mistaken a 1275 cooper s does have these, although im not sure on that. It should also have a breather on the bell housing.
#15 steble
steble
  • 750 posts
Posted 10 April 2009 - 03:20 PM
turns out that my engine cant just be a little metro HL one it must be a sport or gta or something as it has the same size valves as the MG metro does i discovered this when i did a head gasket change the other day
