Mini Estate Full Rebuild
1 reply to this topic
#1 minijames2008
minijames2008
  • 23 posts
  • Local Club: mini rebels
Posted 18 March 2009 - 10:03 AM
Thought it was about time i started a build diary of my very rotten mini estate.The car was taken to my mates house in mansfield so we could get the welding done.Turned out to be rather a lot of welding and about 30 + different panels needed to be replaced.We started work on the car in october but as i live in lincoln i could only work on it on saturdays.
the inner sill on the drivers side was probably the worst part being made up of at least three inner sill repair sections all stitched together.What a bodge.
so the welding included the following:
new floors front to rear both sides including the innersill sections.
new rear subframe mounts
new flitch panels
new jacking points
new door steps
new rear valance sections x3
new petrol tank support panel
new a panels
new narrow sills
new sill stiffeners
new upper rear corners
rear companion bin repair sections
replacement doors and then reskinned both of them
modify the gearlinkage mount for remote gearlinkage
plus loads more that i have probably forgot.
so i will sart adding the pictures to see what you think
Attached File  jamesmini_171.jpg   298.01K   20 downloadsAttached File  jamesmini_142.jpg   355.19K   18 downloads[attachm
ent=82347:jamesmini_168.jpg]Attached File  jamesmini_161.jpg   288.68K   21 downloads[attachment=82345
:jamesmini_117.jpg]Attached File  jamesmini_095.jpg   309.45K   16 downloadsAttached File  jamesmini_083.jpg   279.66K   21 downloadsi_083.jpg]Attached File  jamesmini_264.jpg   374.75K   16 downloadsAttached File  jamesmini_251.jpg   229.4K   17 downloads]Attached File  jamesmini_234.jpg   325.84K   15 downloadsAttached File  jamesmini_194.jpg   332.37K   16 downloads[attachm
ent=82350:jamesmini_182.jpg]Attached File  jamesmini_023.jpg   217.61K   15 downloads[attachment=82342
:jamesmini_077.jpg]Attached File  jamesmini_063.jpg   372.25K   20 downloadsAttached File  jamesmini_046.jpg   192.81K   21 downloadsi_046.jpg]Attached File  jamesmini_031.jpg   235.79K   14 downloads
more to follow
#2 minijames2008
minijames2008
  • 23 posts
Posted 20 March 2009 - 11:04 PM
Hmmm ,seem to have got my pics in the wrong order but never mind.
before the car was put back on its wheels we fitted a new tank and sender ,then added new fuel and brake lines.
The subframes have had new poly bushes and the brakes overhauled,new disks shoes etc.Also added some heavy duty tie bars.
The whole car was stripped to bare metal,the roof had been handpainted so took a while to get that off.Then it was all etch primed ,primed with high build primer and then resprayed in ford calypso green.Not forgetting a few coats of laquer.
Not many colours go with the green that well so i have opted to have black bumpers and mk1 grill,will also be painting the rear window surrounds and petrol tank filler surround in the black.
My mate who did the work for me is building a vauxhall clubby so i have bought his nearly new 13x7 gold ultralite extremes and his mg metro lump.We got these fitted before towing the car back to Lincoln.
the car is just a tight squeeze in my garage but i have started to put the interior and glass back in.
need to get a few more bits yet,the car doesnt have a front wiring loom ,need wheel arches,indicators and some new rubber seals.
Hopefully will have it mot'd shortly.
few more pics of the progress
Attached File  jamesmini_322.jpg   60.66K   15 downloadsAttached File  jamesmini_282.jpg   260.22K   14 downloads[attachm
ent=82547:jamesmini_299.jpg]Attached File  jamesmini_326.jpg   73.67K   18 downloads[attachment=82548
:jamesmini_312.jpg]Attached File  jamesmini_335.jpg   54.92K   14 downloadsAttached File  jamesmini_317.jpg   305.14K   15 downloadsi_317.jpg]Attached File  jamesmini_340.jpg   55.62K   17 downloadsAttached File  jamesmini_338.jpg   80.38K   13 downloads]Attached File  jamesmini_343.jpg   53.97K   19 downloadsAttached File  jamesmini_344.jpg   82.08K   24 downloads[attachm
ent=82556:jamesmini_316.jpg]Attached File  jamesmini_324.jpg   62.14K   17 downloads
