Inertia Or Pre-engaged Starter Motor
Joe_Stol
, Mar 20 2009 05:50 PM
8 replies to this topic
Posted 20 March 2009 - 05:50 PM
Before i go ahead and buy, i was just wondering if a pre-engaged motor is worth the extra money.
I have asked for advice else where but i was told that it doesnt really matter..
So i would just like to get more opinions.
Joe
Joe
Posted 20 March 2009 - 05:51 PM
You don't get a choice. early minis used inertia and later ones used pre-engaged
EDIT... Brainy bods feel free to correct me.
Edited by Git, 20 March 2009 - 05:51 PM.
Posted 20 March 2009 - 05:53 PM
I know that one is already fitted.. but if i am changing engine and i have a choice between the two which one should i choose?
Posted 20 March 2009 - 06:20 PM
The pre-engaged is better in terms of torque output.
However you will need the correct one to match your flywheel ring gear (or change that as well) and you may need to do some re-wiring depending on what your car was fitted with before.
Posted 20 March 2009 - 06:21 PM
also note that the gears on the flywheel will wear out quicker if the wrong starter motor is used, so effectively you would have to change that too
Posted 20 March 2009 - 06:45 PM
I'd just stick with what you have fited already. Both will do the job, and if you stick with the same type you won't have to do any re wiring.
Posted 20 March 2009 - 07:28 PM
It might be more sensible to pick your clutch first. If you're building a fast road/race engine you'll probably want a pre-verto clutch, normally this uses an inertia starter.
Posted 20 March 2009 - 10:38 PM
If you are buying a steel flywheel you can have whatever ring gear you please, also, a ring gear can be easily replaced on any cast flywheel easily for either type you please.
The pre engaged starter is by far the superior unit, especialy if you have a high compression engine
The inertia starter is pants
Posted 21 March 2009 - 01:14 PM
I think like some of you have suggested, it would be better for me to pick the clutch and flywheel first.
But i also like the idea of no re-wiring
I will just see how it goes.
Thanks for all your help everyone!
