Digital Speedo, Is It Possible?
Posted 21 March 2009 - 01:43 PM
i was searching for some digital dash clocks and saw this...
http://cgi.ebay.co.u...-...A1|240:1318
Will it be possible to connect it on the mini? (not only this one, anything like this)
Posted 21 March 2009 - 01:48 PM
Posted 21 March 2009 - 01:53 PM
Yes. Acewell, trailtech...
Does it need much more work? or extra parts added? anything..
thanks for the reply
Posted 21 March 2009 - 01:54 PM
Posted 21 March 2009 - 02:00 PM
You'd need some sort of speed sensor - check out the manufacturer websites
its included. I mean is it ok with the mini and dont need any mods?
Posted 21 March 2009 - 02:21 PM
Posted 21 March 2009 - 02:33 PM
by the way thats a gorgeous set, I really like the look of it. (not 100% keen on the plastic outter but other that its really nice)
Posted 21 March 2009 - 04:32 PM
Ive fitted one myself and they are fairly easy to fit, need your haynes manual or a wiring diagram and you can work out which wires need to connect to what on the clock itself.
The oil temp sender can screw straight into the block or into one of the T's on a T-piece but the water temp sender needs to have an adapter made for it too fit into the head.
For the speed sensor ive found making an L shaped bracket to mount the sensor on off one of the bolts holding the diff side plates on works fine and welding a large blob onto the pot joint for the pick up point
Posted 21 March 2009 - 04:48 PM
Have a look on here http://www.digital-speedos.co.uk/ thats the company who is selling that one, they have a few other options available.
can you post a pic with it fitted to clearly see how big is it?
From the dimension given, it's very small
Posted 21 March 2009 - 05:38 PM
I looks fairly small in that pic, but its very clear when its lite up both during the day and at night. The speedo reading is very easy to read with it being in large numbers. Its really simple to use and setup and tha amount of features available on the clock is amazing.
Edited by Southy, 21 March 2009 - 05:45 PM.
Posted 22 March 2009 - 09:04 AM
http://cgi.ebay.com/...sQ5fAccessories
Also do anyone knows a place to get guages like this with KPH? everything i see is MPH..
Posted 22 March 2009 - 10:22 AM
But begs a question why you want a speedo which reads a full sweep of 160mph when 99% of the time you'll be below 1/2 that...
It's sort of like having a rev counter which will read upto 14k, but when your engine redlines @ 7k, seems a little pointless..
For a gauge to be useful, you really only need it to read say 120% of your maximum value, therefore providing a larger scale for those important readings.
Posted 22 March 2009 - 11:12 AM
Pretty much anything can be "made" to fit...
that's just an example of what clocks i am looking for (visually), not the one i am going to buy.
Posted 22 March 2009 - 11:45 AM
Posted 11 April 2009 - 10:23 PM
http://www.theminifo...500/ppuser/8950
