Monster Turbo/supercharged Head 36-32 Offset Valves 26.5cc
1 reply to this topic
#1 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 22 March 2009 - 07:21 PM
I'm not sure if i should have put it in the for sale section ? But i thought it would be more relevent here.
Monster Turbo/Supercharged Head 36-32 Offset Valves 26.5cc
Right, up for sale here is a bit of a special & seriously modified Turbo head. I did this for somebody but they've let me down. Theres a lot of time, money & machining gone into this head so i need to move it on.
The head has been pressure tested, both the head & manifold faces have been skimmed, it's painted & ready to go.
The head has been offset drilled & special custom Colsibro bronze guides made to allow fitment of a 32mm exhaust valve with the 36mm inlet.
Chambers.
Enlarged, polished & balanced 26.5cc
Inlets.
Fully ported inlets with bulletnosed silicone bronze guides. These guides taper down right into the head, not just a slight taper at the end like some. 36mm Nitrided 21NS stainless steel race valves with waisted stems. 3 angle valve seats. Single groove collets & caps.
Exhausts.
Fully ported & polished exhausts. Custom oversize colsibro offset bronze bulletnosed guides. 32mm Nitrided 21NS stainless steel race valves. 3 angle seats. Single groove collets & caps.
Springs.
180lb double valve springs.
The same spec head at MED is £750 !!
I usually sell these for £485 http://www.turbo-min...091/64366.html but i'm willing to let this go for £460.
With the amount of time & effort it takes to produce one of these, that's a bargain.
Phil.
Edited by Turbo Phil, 22 March 2009 - 07:23 PM.
#2 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 March 2009 - 08:53 PM
Head now sold. :wub:
