1992 Spi Cooper
94500 mls.
Changed the raditor for a non SPi radiator (without the aux fan sensor) straight swap fitted no problems. Bled and topped up accordingly.
Prior to the swap (despite the old rad leaking) engine temp was a needle width below the half way line.
Now the temp barely gets off the lower white (cold) marking.
Car idled previosuly perfectly at approx 900rpm.
Car now running rich (sooty deposits on rear bumper) and idels at 1500rpm.
I suggest that this is due to the ECU realising that the engine is not "warm" and overfuleing.
The rich running happend previosuly and all I did was change the Air Temp sensor- however i have not come accross the low indicated engine temp.
Help please as running rich is not good for the car or my pocket!!
BM
Running Temperature.
Big Man
, Mar 23 2009 05:31 PM
6 replies to this topic
Posted 23 March 2009 - 05:31 PM
Posted 23 March 2009 - 06:00 PM
have you checked the thermostat, it might be stuck open or something?
Posted 23 March 2009 - 06:03 PM
to be honest no I havent checked the thermostat, will get one and change it on Wednesday! just seems a little coincidental that all was fine and dandy before i changed the Radiator and now everything has gone to rat!
BM
Posted 23 March 2009 - 06:08 PM
sometime these thing happen at the same time! my thermostat was stuck open when i bought the car and it was never getting up to temp and running rich. Id changed the plugs and leads thinking it was that, but it was the stat
Posted 24 March 2009 - 09:25 AM
Will fit new thermostat tomorrow....... how about an air lock somewhere??? As when heater on temp really low.....when heater off (cold) temp gauge rises??
BM
BM
Posted 25 March 2009 - 12:29 PM
thermostat changed....bledd system for a good half hour result:
Temp is now a needle width under half - perfect!
Idle when warm is approx 850 - 900 rpm - happy
heater - red hot
Thanks COOPERMPI
BM
heater - red hot
Thanks COOPERMPI
BM
Posted 25 March 2009 - 01:57 PM
no worries, glad to have been a help!
