Odd Stepper Motor
Posted 26 March 2009 - 08:47 AM
Car runs fine, no problems with running, smooth and how it should be.
However every so often the car skips a beat and the stepper motor sticks at the revs it was at, so if i was cruising at 2k if it skips a beat the idle will be 2k. If i drive a bit at between 200-500 revs higher the stepper goes back to normal.
The odd occasion (especially if it did it when coming to a stop) i need to turn the engine off, wait awhile then restart and its fine again.
Any ideas where to start looking, code reader brings up no faults and everything reads correctly.
Ta
Jackman
Posted 26 March 2009 - 09:05 AM
Just my thoughts
Rob
Posted 26 March 2009 - 09:11 AM
Didnt think about the stepper thing on the code reader
Good having a brainstorm with someone about it. Strange thing is it always happens after a skipped beat.
Shall check it out tonight if i get chance, if not will be next week now as im away at weekend.
Posted 26 March 2009 - 09:24 AM
Rob
Posted 26 March 2009 - 10:21 PM
I would be sure to tune the stepper so that it is about 40 steps at warm idle speed. What is the stepper at, at the moment when its idling warm?
The stepper motor follows the throttle movement, to catch the throttle on release of the accelerator pedal, and lowers the engine speed gently to idle without over shooting and stalling. A low step count at idle can and does cause the stepper to hold the throttle and engine speed above the threshold for idle codition, the ECU mistakenly thinks that the throttle input is by you. The stepper just sits there and the revs dont drop. if the revs dont drop, the stepper will not retract.
you need to watch the stepper motor count to see what is actualy going on. I would check the crank trigger, make sure it is still tight and in the right position
Posted 27 March 2009 - 08:01 AM
I had a problem that looked like yours a few month ago, it was due to the idle control valve. I forgot to plug it and it gave the same symptoms.
Edited by El Chibro, 27 March 2009 - 08:01 AM.
Posted 30 March 2009 - 07:50 PM
Will give it a full check over tomorrow though, air gap of the crank sensor seems to be ok still.
Posted 31 March 2009 - 11:33 AM
On warmup the stepper goes to 72ish then drops and sits at 60 steps. Tested the range of the stepper, it goes all the way out then goes back in freely.
See how it is tomorrow, i used the tune stepper function and it seemed to be ok.
Posted 31 March 2009 - 12:36 PM
Rob
Posted 31 March 2009 - 09:11 PM
to be honest it doesnt really matter as long as its not below 20 and above 40
Posted 01 April 2009 - 09:58 PM
I think its a dodgy cable somewhere
Posted 02 April 2009 - 07:03 PM
Are we talking car here or life in general....lol
its rare to find someone with a PERFECT A series so dont feel isolated in this respect...lol.... so you must be talking life...... and it cant be perfect unless you have a girlfriend like mine....lol...... so I have a perfect life and an imperfect A series... how good can it get......
Sorry if this is a bit off topic...... might see you at Minis Vs Beetles
...... good luck with the ' dodgy cable '..... they arnt easy to trace.... not without a scope and some time..... and especially with the stepper function......
Keep us updated
Rob
Posted 02 April 2009 - 07:55 PM
