Bucket Seat And Harness Install
4 replies to this topic
#1 Bobby9779
Bobby9779
    Two carb man
  • 1,346 posts
  • Local Club: H4H Mini's
Posted 26 March 2009 - 09:53 AM
I have got the funds and know what i want to buy now.
Cobra Monaco bucket and sparco 4-point harness.
What other bits do I need to get this fitted?
Seat subframe! Is there anything else?
Cheers all.
Bob
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 26 March 2009 - 10:05 AM
Some eye bolts ( if the harnesses are clip in ) and loose your back seat.
Using eye bolts allows you to put the harnesses in without removing the original front and rear belts, so you can use your mini as both a 'normal' every day car, and put the harnesses in when you want to.
Off the top of my head you'll need ones with a 7/16" UNF thread.
#3 Bobby9779
Bobby9779
    Two carb man
  • 1,346 posts
Posted 26 March 2009 - 10:20 AM
Good tip, cheers.
Will the eye bolts come with the harness kit or does the harness kit bolt straight into the rear seat frame.
Bob
#4 mini mad
mini mad
  • 50 posts
  • Local Club: Crewes Missiles
Posted 26 March 2009 - 12:15 PM
I bolted mine where the seatbelts are ment to go and though the rear seats.
Chris.
#5 stooart
stooart
  • 168 posts
Posted 26 March 2009 - 12:47 PM
Hey, sorry to bump into this topic but in about a weeks time i will have near enough the exact same set up with buckets and sparco harnesses. I still want to be able to use my front seatbelts but not bothered about the rear. Any one know of where i can get the eye bolt/clips or what ever there called!?
also, will they need to be welded in or is there another way of attatching them?
thanks! Stu:D
Edited by stooart, 26 March 2009 - 12:48 PM.
