I'm in the process of dismantling my engine and got held up by a nut i couldn't undo on the cylinder head!
I have undone 8/9 nuts but the last one just won't shift! It's the one on the spark plug side of the cylinder head nearest to the flywheel.
I have tried oiling it, using a spanner and hitting it with a mallet and it still wont shift!
My spanner has started to slip around the nut now and is rounding it off making it even harder to undo............i'm very tempted to take a grinder to it? I'm using this engine as a basis for my new turbo project so will have to get new and stronger cylinder head bolts anyway therefore it doesn't matter if i damage the bolt in the process!
I just wondered if there is something else i could try first that might work? Anyone had a similar problem? I don't have a clue why that one is soooooo tight compared to the others????
Any help would be greatly appreciated,
Cheers,
Mike
