I have a 96 cooper with two alarm fobs. One works fine, the second does not, so i have just changed the battery. Still does not work, is there a way it can be "taught" by the working alarm fob? If not, any suggestions. thanks.
Alarm Fob Not Working
Neil H
, Mar 27 2009 05:07 PM
2 replies to this topic
Posted 27 March 2009 - 05:07 PM
Posted 30 March 2009 - 10:17 PM
hi the remotes have to programed by a rover garage with the machine that plugs into the car this is the only way,gotta get mine done too
hope this helps
dan
hope this helps
dan
Posted 06 April 2009 - 11:09 AM
The fobs are pretty fragile, if you drop your keys/fob often, or just chuck them about, the circuit in the fob gets damaged, and it basically forgets all the programming.
My old fob did this a whilse back now, and I needed to get a new fob and get it programmed in! Cost a fair bit...
If your other fob works fine, then just use that, and be careful with it!
