Lucas 23 D4 Distributor Contact Set Part Code?
5 replies to this topic
#1 rendersonique
rendersonique
  • 386 posts
  • Local Club: http://www.dcmoc.co.uk
Posted 29 March 2009 - 09:09 AM
Can anybody provide me with the correct contact breaker part code for my Lucas 23 D4 distributor (mk2 cooper S) as the local motor factors arn't quite sure? Have had a quick look on minispares and google but I can't seem to find anything concrete.
The link below is from the Intermotor webpage which is the supplier the local motor factor uses. Is it correct?
http://partfinder.sm...amp;value=22560
#2 tommy13
tommy13
  • 878 posts
Posted 29 March 2009 - 10:37 AM
If the low tension wire is cloth bound and attached with a small nut they are Lucas DSB101
If the low tension wire comes through a hole in the side of the distributor and is attached to the condenser wire DSB108
Putting these part numbers into E-bay will bring up images.
Edited by tommy13, 29 March 2009 - 10:45 AM.
#3 Nightrain
Nightrain
  • 976 posts
Posted 29 March 2009 - 10:49 AM
Sorry those where 25D's, try a MG or Triumph specialist's, early MGB's had the same dizzy pretty sure some triumphs had as well.
Edited by Nightrain, 29 March 2009 - 10:54 AM.
#4 tommy13
tommy13
  • 878 posts
Posted 29 March 2009 - 02:10 PM
The Lucas DSB 101 formerly CS 1 fit the 23D distributor. These cross ref to Intermotor 22560. The DSB108 (Intermotor 22580) fit the 25D dizzy, I only made mention of it as I wasn't sure where the OP got his info from on distributor type and it may have been changed for a later one at some point.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 March 2009 - 03:04 PM
I'm not sure of the Lucas number but I believe the Unipart number is GCS101. I also thought there was a high spring force set of points for the Cooper-S but I can't find a record of that part number. I'll look in my collection of parts and see what I can find.
I don't believe the MGB or Sprite/Midget ever used the 23D4 from the factory though they were often fitted by Spridget owners.
#6 rendersonique
rendersonique
  • 386 posts
Posted 29 March 2009 - 08:44 PM
I would just like to thank you all for the info you have provided. I now have the points and condenser so I guess its ;D
Andy
