i've done a quick search and haven't found anything.
I've got thedisc breaks that were standard from around '84 on, i've taken the discs off along with the calipers but i wanted to take the drive shafts out of the hub so i can clean the hub up. will i need to replace the bearings and stuff if i do?
The whole unit is off the car the shaft has been removed from the engine end.
attached should be a photo i've what i've got, i hope i've explined it in enough detail, let me know
cheers
tractor
