Hi just a quick one just brought some 1040 semi sinthetic oil to run in my new engine done some miles already so not brand new will this be ok .
best regards lee
1040 Oil
leepol83
, Mar 31 2009 07:27 PM
5 replies to this topic
Posted 31 March 2009 - 07:27 PM
Posted 31 March 2009 - 08:39 PM
That'll be a disaster for running in on. Sinthetic oils should never be used in a mini, i don't think even racers use sinthetic half the time.
For running in you essentially want the cheapest mineral oil you can find, this is so the new piston rings will bed in properly. If you use sinthetic oil you will almost certainly glaze the bores.
Have a read: http://www.theminifo...showtopic=53037
Posted 31 March 2009 - 09:45 PM
So I should use 20 -50 halfords oil then for running in.
No one really mentions running in on the thread ive just read but the 20-50 seems popular
Posted 31 March 2009 - 09:50 PM
dont use synthetic oil in a mini..you will ruin it..use an ordinary 20/50 oil and change it after 500 miles....
tog77
tog77
Posted 31 March 2009 - 10:16 PM
Thats great thanks for all youre help 20-50 it is then..
best regards lee..
best regards lee..
Posted 31 March 2009 - 10:32 PM
Yep you've got it, run in on any old 20/50 then you can choose to switch to a higher quality oil after the engines run in - which could be 20-1000 miles depending on what you've read/believe is best.
Just for info, halfords oil is all made by Comma and is equivilant to the second best oil in their range - So essentially, good for the money.
