JL speaker choice opinions?
Posted 27 August 2005 - 10:02 PM
I was looking at:
JL XR525-CXi 5.25" Coaxial
JL XR650-CXi 6.5" Coxial
I just wondered how good they are and i also wanted to know if they should be used with a sub as i didnt really want to use one.
Mike
Posted 27 August 2005 - 10:54 PM
Small speakers dont give off much bass at all. If they are mounted on dense wood, they will be a bit bassier but not much.
<|Ben|>
Posted 28 August 2005 - 01:43 PM
Posted 28 August 2005 - 01:50 PM
Any recommendations for a good set of components?
Would it be a benifit or drawback if i had a set of comps in the back aswell as the front?
Thanks for the help.
Mike
Posted 28 August 2005 - 02:47 PM
It's normally always a drawback to have anytype of speakers in the back other than sub's, because sub's produce Non directional frequencies so it doesn't matter where they are placed in a system. Where as all other speakers are directional meaning u can pick up where the sound is coming from. So if sound is coming from behind u, u will pick this up which is a BAD thing. The human ear is design to pick up sounds facing u the best that why when ur trying to hear something u face it.
Any type of speaker other than a sub can't produce sub bass note's really without spending thousands. So u see to get good sound quality u really need a sub or else u would be missing an essential part of the musical frequency. It's not just for boom boom type music
This is why a good systems can usually be as simple as comps in the front and a sub in the back, this way the whole musical frequency is covered. However u said u didn't want to get a sub so there are alternatives but it depends on ur budget.
Posted 28 August 2005 - 02:54 PM
I was told that an 8" sub would suit the type of music that i listen to (Fast paced metal and hardcore). Is this true and any recomendations if decide to install 1?
Posted 28 August 2005 - 03:19 PM
These are amazing sound quality comps:
http://www.caraudiod...31c15cec8f147cf
Slightly less SQ but still very good but with more bass:
Something in between them both:
Posted 28 August 2005 - 05:09 PM
Posted 28 August 2005 - 05:18 PM
Posted 28 August 2005 - 08:08 PM
Posted 28 August 2005 - 10:03 PM
subs -bass, mids-high midbass n vocals, tweeters-high tone n treble!
have any speaker do all of this it wont take it for long !
and amps are cerainly worth saving up for ! 10 fold !
i ran boston acustics in my last car and it was flawless! took it to a silvestone sound off comp in 99 it came 6th! £2,750 complete install.inc wire alpine head unit !etc first place had spent £9000+
jl audio are damn good size dont matter ! go for high quality ! trust me it pays !
you can have a 100 watt speaker blow your doors off running off a 35 watt amp
and have 250 watt running off 150 watt amp and sound poo!!!!
(examples not specific)so down shep! lol
Posted 29 August 2005 - 05:27 PM
I really wanted something that will fit under the rear seats, but the only 6.5" subs i could find were these:
6.5" Subs
I was thinking of fitting to 6.5" subs in a speaker board under the seat.
Any idea if the JL ones will be any good and if not any other recommendations for a 6.5" sub that will suit what i need and maybe a good amp to power 2 of them?
Mike
Posted 29 August 2005 - 06:23 PM
as for a amp:
http://www.caraudiod...c4d41e3f4efe349
the reason I suggest this is because u can then run a pair of subs of this amp quite easily and ur comps of it for know until money allows u to get a better SQ amp although this will be quite good, then u can bridge the 4ch down to a 2channel amp and give the subs abit more power aswell.
Forgot to ask what comps did u decied on?
Posted 29 August 2005 - 06:29 PM
Thanks for all the help, its appreciated.
