whats the best method and tool to grind welds down as using the grinder can make a mess
i have an angle grinder and an orbital sander
Whats Beat To Grind Welds Down
feybrand
, Apr 01 2009 08:09 PM
6 replies to this topic
Posted 01 April 2009 - 08:09 PM
Posted 01 April 2009 - 08:14 PM
Angle grinder probably is best, other that than you could use some of of Dremel for small bits or I sometimes use my Black & Decker Powerfile which is a great tool I would be without
Posted 01 April 2009 - 08:15 PM
I use a cutting or grinding disc to remove most of the weld...then when you need to be more careful, use a flap disc or another type of sanding device.
Ed
Ed
Posted 01 April 2009 - 08:16 PM
i use 40 grit fibre disc on a grinder or a belt sander if you cant get the grinder to the weld
Edited by gtb, 01 April 2009 - 08:17 PM.
Posted 01 April 2009 - 08:18 PM
I'll be the first to say...
DON'T CUT WITH A GRINDING DISC OR GRIND WITH A CUTTING DISC!
Posted 01 April 2009 - 10:20 PM
Flap discs are the best if you want seamless looking joints.
Posted 02 April 2009 - 11:38 AM
Yeah , im all for flappy discs. Machine mart ones are cheap and they work for ages and when they are tired you can still use them for tidying up and smooting things that a new one would eat away.
