Firing problems!!!!!!!!!!!!!
4 replies to this topic
#1 Guest_Beno_*
Guest_Beno_*
  • Guests
Posted 28 August 2005 - 01:03 PM
I have just fitted a 1293 to Grover, but can i hell get it to run right :rolleyes: Ive checked the firing order its fine i think 1-3-4-2 ! !
Im a little confused to why it will only run when i near enough fully advance the timing :cry:
It will run but is very missy and spluttery !!!
Any idea's ??????????
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 August 2005 - 02:50 PM
is the dizzy cap 180 degrees out
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 August 2005 - 03:33 PM
are the ht leads ok?
I just got home, i might be around later if you need me Beno, but i can only think this is down to setting rather then the engine.
Have you tried another dizzy?
#4 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 29 August 2005 - 12:26 AM
i'd have said look at the dizzy, not too sure if it would run at all with it 180 degrees out, but i dont have the experience to definatley say
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 August 2005 - 04:21 PM
Since it sounds like you've done a complete engine swap, start with checking the basics.
As mentioned, the firing order is 1-3-4-2 with the plug leads going CCW around the cap. Number one spark plug lead should be somewhere in the vicinity of 1 o'clock to 2 o'clock. Your #1 spark plug will be the one closest to the water pump. (Verify this is so by looking at where the rotor is pointing on the cap when you've got the timing marks lined up). If you're running points, make sure they are gapped correctly. Finally, once those have all been checked, check the static timing and set it for what is correct for your engine. If you don't know and can't have a resource... guess at 5 BTDC and you should be able to get the engine to start.
