Brake Fluid - Should It Be This Colour?
Posted 05 April 2009 - 07:13 PM
Posted 05 April 2009 - 07:38 PM
Posted 05 April 2009 - 08:22 PM
so ovetime the water works on the back of the caliper pistons and the inside of the braking system making rust particle
brake fluid needs changing a minimum of every 2 years
i do mine every year makes a huge difference
also brake fluids a lubricant so sticking brakes can normally be traced to old fluid
Posted 05 April 2009 - 08:49 PM
Brake and clutch fluid should be replaced at the same time and at least once a year.
I suggest that you consider buying alternating coloured fluid too - you can get the honey coloured dot4 as well as green dot4. That way when your bleeding and flushing etc you will start to see the new fluid easily and means you use less fluid !
Posted 05 April 2009 - 08:56 PM
That smacks of seriously
I'm liking your work sir!
Posted 05 April 2009 - 09:07 PM
Yes very old fluid there.
i like that idea! - funky coloured brake fluid - this mini lark is more fun than i could ever have imagined!!
Posted 06 April 2009 - 11:47 AM
My old LC had Red 2T oil, green gearbox oil, blue coolant and yellow brake fluid.
With clear hoses wherever possible it was quite funky!
