Changing A Differential
4 replies to this topic
#1 Bevan
Bevan
  • 736 posts
  • Local Club: On the search!
Posted 06 April 2009 - 10:55 AM
After a crunch and a big loss of oil the other day I have fianally got round to inspecting the damage that has been done.
Differential casing has a big crack and is leaking oil from it, so chances are it doesent look too healthy inside.
Question is will this be an engine out job? I can see bolts holding the casing on but if the diff inside needs changing then the gearbox will have to come off?
Them driveshafts look a pain to get out too, am I right in thinking I will be needing some sort of special tool apart from a pry bar?
#2 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 06 April 2009 - 11:15 AM
To be honest, I would think it wise to have the engine out and take a good look at the gearbox while you are at it... if something has gone bang then there's a good chance of damage or at least some nasty bits in the gearbox too :lol:
#3 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 06 April 2009 - 11:57 AM
A work coleague has had the same problem with his autotest mini.
Against my advice he just took the diff housing off with the engine slid forward but then found the planet gears had both smashed and wasnt sure how many chunks were still in the engine.
His motor is now out and being stripped down to assess the rest of the damage.
As per the last post Its not really worth messing with it.
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 06 April 2009 - 12:46 PM
To fix a cracked diff casing you will need to replace the whole 'box casing really - they are a matched pair when manufactured.
Coupled with the fact that something has probaby died inside I would bite the bullet and look for a re-conditioned 'box complete. There was one in the For Sale section this morning.
#5 Bevan
Bevan
  • 736 posts
Posted 06 April 2009 - 12:52 PM
Yer I think I will play it safe and get the whole lot done. It needed a new gasket around the gearbox/block as it was leaking very slowly anyways. Just means I wont be able to make South Central RR or L2B :lol:
On the up side, atleast it didnt break on me on the rollers!
